Question about LG LSC091PMA Split System Air Conditioner
LG split system heater cooler. the heater is not working and fan outside is working
We have an LG split system cooler/heater the heater is not working and we just had it regassed today. it works on the cooling setting. the fans outside the house are going even when the heater is turned on at the thermostate
    President:
  • 1,902 Answers
I would check to see if the tech accidently left his jumpers on the unit to keep it running while adding freon. I know it sounds like a simple thing. But all techs have done it at one time or another and that will cause this problem. Due to the fact that you just had freon added there is not a reason anywhere that would cause you no heat unless something was hit when this was being done then something electrical fried
Posted on May 28, 2009
LG air conditioner 24awn error code message Ch 6 inside fan runs outside unit not working
CH-06 REFERS Indoor unit coil sensor fault. Disconnect from PCB measure resistance. 10 kOhm at 10C and 4 kOhm at 30C. if not replace sensor. THANKS.
Dec 13, 2010 | LG Art Cool LA121HNP Split System Air...
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Is a split a/c alc and a heating or heat pump?
a split system can be gas or can be a heatpump. a split system is when the condenser coil compressor and outdoor fan is outside. the other half is in the house close to your air filter .that well be your air handler. eletric heater. or gas burner .and indoor fan motor would be. i hope that helps you.
Apr 15, 2010 | Cfm Daikin R410a Split System Air...
My LG intelloair 1.5 ton split a/c's compressor not working.
check the compressor's start/run capacitor. if it is swelled at the top, where the connectors are, replace it.
Apr 04, 2010 | Heating & Cooling
My LG LAN125 mini split heat pump occasionally shuts down in cooling mode while displaying the code CA. The LG tech tells me there is no such code. When this happens, I have to cycle power off and back on...
Wash out your outside coil and monitor the outside fan. sounds like a lockout due to dirty condenser or intermittent motor operation. Could mean condencer air problem.
Jun 28, 2009 | LG LS-L1210CL Mini Split Air Conditioner
LG split system cooler/ heater heater not working
This could be a problem with the interconnecting wiring or a control board problem with either the indoor or outdoor unit. I would have these issues looked out.
Hope this helps
Mat
May 28, 2009 | LG LSC091PMA Split System Air Conditioner
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
Installing a sump heater or cold weather use.
air conditioner can work at 0 deg C outside temp and you do not need a heater for compressor if is split system.
Feb 17, 2009 | LG LB1200ER Air Conditioner
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
LG LSC091PMA Split System Air Conditioner Logo
432 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
