Question about Compaq Computers & Internet
The screen turns black
Computer works fine. the screen turns black after a while. i can shut it off then it will come back on again for a little while. this is the second screen thats doing the same problem once i hooked it to the computer
  • Compaq Master
  • 4,806 Answers
Hi there.
Its not the screen, its the display settings that has to be changed.
Go to the control panel and select power options, in power options look for select when to turn of the monitor and set it to never as its probably set to turn of after 20 minutes or so also set the hard drive to never turn off, save the changes and the problem should not arise again.
If you need anymore help or advice please post back.
Good luck and thanks for choosing FixYa!!
Posted on May 28, 2009
In the middle of a session the screen turn black, but the computer seem to be on... we need to stop it with the middle button and restart it again. Usualy it start back normaly again. But one time, instead...
You need to start up in safe mode you do this by pressing F8 while it is booting up you will then see a screen that says start normal or safe mode pick safe mode if it boots up and it will take a little while then shut down the computer by selecting shut down and then restart this will most likley solve your problem
Jan 13, 2011 | Acer Aspire 4520-5582 Notebook
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
No picture, good audio. Replaced motherboard...
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Feb 12, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Toshiba M115
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me".
Would initially suggest to clean the memory(/ies). Turn over the laptop, behind one of the panels/lid/cover secured by a screw or two would be the memory modules. Snap them out, use a hard pencil eraser to clean the little gold pins, a dry brush on the memory slots and re-insert the memories back, try again.
Should this be not corrective, it would appear that you have a video driver problem and fails to load correctly. Try booting into "Last known good configuration that worked", otherwise might require re-installing Windows all over again, sorry.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 14, 2008 | Toshiba Satellite A100-S8111TD Notebook
My monitor works for a little while, then goes black.
Your power-inverter board needs an overhaul.
Probably in need of the standard capacitor replacement.
OR
a bulb in the screen is bad (a bad bulb will usually show symptoms)
It will flicker, or will look pinkishish for a bit or dark in the middle top or bottom of the screen.
ebaysbammbammfran
Oct 11, 2008 | E-Machines eMachines Monitor E15T4
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Computers & Internet Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
