Check behind the paper draws for any paper jammed back there . ALSO DO NOT STORE EXTRA PAPER in the draws that extra space is for if the draw is set up for 11x17 paper!!!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: how to solve bizhub 211 code error c0650
bizhub 211 error code C0F32, To solve this code simply replace the developer of the machine.
SOURCE: ihave error code c5oo c501 in bizhub 211
The C-500 - Warming up failure.Check the fuser heater lamp continuity,end the thermofuses.
The C - 510 Abnormally low fusing temperature.Verify the thermofuse and thermistor.
For reset the malfunction codes press the switch located on display right side (a little hole) wait to appaire in central left side on the display * and press 3 and touch the Trouble reset mode.,and press Exit,the copier turn ON automatically.
