Question about Reebok Vista Treadmill - RBTL13305
Reebok i run treadmill stops working after 10 mins
I have a reebok i run treadmill.. when i use it after 10 mins the Blet stops moving but everything else is still working fine. How do i fix this problem ?
    New Friend:
  • 64 Answers
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
Posted on Jun 08, 2009
  • 11 Answers
When you power up the treadmill ensure the progam you choose is p1, as you may have pressed the select mode button by mistake and the treadmill is on a 10 minute countdown??? if the belt stops at exactly the same time every time then this is what has happened...it is easily done! jamie
Posted on Jun 18, 2009
How do I get my I run reebok trademill to move
If you push start and the belt does not move then it seems like the is a problem. This problem may be the LCB.
Nov 24, 2013 | Reebok Vista Treadmill - RBTL13305
Treadmill stops running after 10 mins,won't start for about an hour
LUBE the deck belt +rollers bearing. This happen because lack of lube and maintenance according with the s. maintenance
see the video
God bless you
Jan 11, 2013 | Reebok Exercise & Fitness
The running belt has come off my reebok I-run
1) Lube the deck belt inmediately, this happen because the electronic system protect itself, shut down.
2) Lube the rollers bearing very well
3) MEAsure the voltage input motor, if there are the motor need repair
4) Measure the output voltage board, for input voltage motor, if there are not THe board is faulty.
see the block diagram
God bless you.
Jun 18, 2012 | Reebok treadmill i-run s
Hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
May 14, 2010 | Reebok Exercise & Fitness
How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
Mar 07, 2010 | Reebok Exercise & Fitness
The belt won't move and the incline is stuck. display isn't working properly either
reebok 8000es incline keeps going up and down and will not stop or go into any other mode
Mar 01, 2010 | Reebok 8050 ES Treadmill
Where can i get a reebok TR3 treadmill user manual
Updated linkhttp://www.iconservice.com/CustomerService/manualsProductManuals.do?model=RETL1600&modelName=REEBOK+RT1000+TREADMILL&version=1&company=11&language=
Oct 25, 2009 | Reebok Rt1000 Treadmill Walking Belt
Reebok i run stopped working after 5 mins power light on . display screen blank
it sounds like it may be the fuse on the motor circuit board? if you unscrew the motor cover and have a look inside(ensure you have turned the power off) you will see the circuit board and the fuse is in the middle. take it out and have a look to see if it is intact. go to Maplins and ask for a replacement as it is not a standard fuse, it is a 'time delay fuse'.
if this does not resolve the issue, you may need a replacement motor circuit board (around £40) which is very easy to replace. if you need help doing this let me know and ill guide you through it.
Apr 16, 2009 | Reebok Vista Treadmill - RBTL13305
Reebok Vista Treadmill - RBTL13305 Logo
2,771 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
