Question about Canon PC-921 Black and White Copier
Paper Jamming I have a Canon PC 921. This morning when I tried to copy something it made a weird kind of low squeaking noise - like rubber rubbing against rubber - and then the paper got jammed. How do I fix this?
    Master:
  • 409 Answers
See if canon sell a Roller PM kit and replace the rollers.  you could try cleaning them with a lint free cloth and some fresh water.
Posted on May 28, 2009
Cannon pc 921 won't feed paper from tray or bypass, shows P for out of paper but tray is full I can't find any jam
Try cleaning the feed roller using ammonia solution. The sizing used in the manufacturing of paper has waxy substances that accumulate in the pores of the rubber rollers and reduce the friction on the feed roller..
May 29, 2014 | Canon PC-921 Black and White Copier
Canon pc-921 squeaking noise
1- might be the scanning rail -- if you can open and lube LIGHTLY slide scanner back and forth ( w power off)
2- caould be Drum, some make a whistling/ hollow sound
Sep 05, 2012 | Canon PC-921 Black and White Copier
Dark streak on paper
you need to clean the rollers. consult the manual about cleaning the copier. if you don't have a manual, then get some methyl alcohol (any alcohol that evaporates completely will do). use a lint free cloth to rub a small amount of alcohol on all roller surfaces (accessible via pull-down compartments on front and back, usually).
Nov 29, 2011 | Canon PC-921 Black and White Copier
Why is cooling fan making weird noises
Depends on what the weird noise is...kind of a squeak? Fan bearing are going out....clicking or dragging sound? the fan blade is hitting something....
Feb 08, 2010 | Toshiba Satellite A45-S130 Notebook
What button do you push, or how do you make a double sided copy on this machine...I've been stuck for awhile. thanks
Canon PC 921 copier does not offer automatic duplexing. It is possible to copy first side, then take the copy and feed it into the bypass (manual) feeder on the right side of copier with printed side facing down or placing in paper cassette printed side facing upward. Don't forget to change your original for second side.
Nov 19, 2009 | Canon PC-921 Black and White Copier
I have a Canon PC790 and every time I try to copy, I get an error message in the paper select part of the control panel. I checked for a paper jam, seems like it isn't picking up the paper. I can't find...
Remove the paper tray and clean the feed rollers on the right side at top. I would use a cotton ball with rubbing alcohol on it. Make sure the rollers are dry before trying to copy again. Let me know your progress.
Nov 02, 2009 | Canon PC-921 Black and White Copier
How to avoid paper jams?
hi,the best way to avoid paper jam is cleaning.clean
first paper transportation area,second paper feed rolls in trays.send me result
May 31, 2009 | Canon PC-921 Black and White Copier
Canon PC-921 copy machine error message "P"
Load paper.If there is paper in the tray,there is a problem with the paper pick up.Try to use the Manual feed try.
Oct 26, 2008 | Canon PC-921 Black and White Copier
Roller stuck
you may have simply just dislodged the feed assembly, remove your tray and inspect the under carriage, its a start and see for anything out of place...
Mar 26, 2008 | Canon PC-921 Black and White Copier
Canon PC-921 Black and White Copier Logo
136 people viewed this question
old marine
old marine
