Question about Whirlpool GD2SHGX Refrigerator
Odor coming from back of refrigerator and bottom not from inside
Bad order smell
  • 159 Answers
It can be gas that are leaking from the system
Posted on Jun 01, 2009
It has a bad smell coming out of motor area
Hello friend, thank you for your post!
I understand that you are having an odor issue with your Frigidaire refrigerator. Usually odors can stem from spills or food within the refrigerator. You can clean the interior with warm soapy water or warm water and baking soda.
Another home remedy is using a pan of charcoal (do not use the one that contains lighter fluid) or kitty litter inside the bottom of the refrigerator and that can help clear out an odors within your refrigerator. I hope this has been helpful. -Matt
Oct 19, 2014 | Frigidaire Refrigerators
What gives our refrigerator has a bad odor inside it
Hey friend, thank you for your post!
I understand your Frigidaire refrigerator has bad odor inside of it. Typically bad smells inside of your refrigerator come from food with strong odors, they can circulate throughout your appliance and attach to the evaporator or walls of your refrigerator. Here are some steps you can perform to help eliminate the odor.
· Washing the walls with warm soapy water.
· Washing the walls with warm water and baking soda. Do not mix other products with bleach.
· Place a pan of charcoal inside the appliance. Do not use self-starting charcoal.
· Place a pan of kitty litter inside the refrigerator.
I hope this information provides useful. -Matt
Aug 17, 2014 | Frigidaire Refrigerators
Why does my electrolux refrigerator have a bad smell coming from inside
Hi ralexander73 - Are you referring to a plastic odor that the unit is providing? If so, this is typically caused by blocks of foam located on the sides of the evaporator coil being deformed by heat from the defrost heater which only a professional can repair. If not, what type of odor do you smell? With this information, I will be better to address the issue at hand. Thank you.
Feb 24, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Freon leak in refrigerator?
no refrigerant leaks have little to no odor and if it was leaking bad enough to smell it the unit would be out of refrigerant and not cooling...the problem sounds like gases coming off of a veggie of something un-covered inside the fridge--have you put any veggies in the fridge or freezer un-covered check real good if one or a piece of something has fallen behind something else where you cannot see...all else fails remove all your products from the unit and clean and get a box of odor control arm&hammer to rid the smell..as for a leak in the sealed system i think your just fine.
Mar 27, 2012 | Samsung RF265AA Bottom Freezer French Door...
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Odor coming from bottom of fridge
sound like drain blocked clean out with clorine bleach (not to be used inside frige/freezer). are you trying to grow your own pennicillin.?
Feb 11, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Smell developed in refrigerator, it is thoroughly clean
The drain is at the bottom inside the freezer section. It is possible a piece of something got behind a panel, or otherwise in a "hidden" spot. Or something is in the defrost water tray underneath and every time it defrosts, it gets wet and releases the odor again. Look in the drain pan by removing the kick plate (bottom grate under the doors) and look to see if anything is there. Use a few open boxes of baking soda in the fridge (to absorb odors), and wipe the inside with some vanilla extract. that combination will help with the odor. But the source of the odor needs to be removed first. It sometimes can be hard to find.
Jan 11, 2010 | Whirlpool GC5SHEXNS Side by Side...
Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Jul 03, 2009 | Kenmore 50522 / 50524 Side by Side...
Refrigerator odor
hi there,
the bad odour could be from the compressor, evaporator or heat exchanger. can you supply the complete model # please?
thanks.
Sep 25, 2008 | Whirlpool Refrigerators
Very bad odor in Maytag refrigerator
There is a very bad smell from the bottom of the refrigerator . There is a pan under the refrigerator with a very bad smelly Liquid , How can I clean that pan I couldn`t pull it out ? Thank you
Feb 20, 2008 | Refrigerators
Whirlpool GD2SHGX Refrigerator Logo
137 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
