Question about Porter Cable 361 3" X 24" Sander
How do you replace the drive belt on a Porter Cable Belt Sander
I have ordered and received a replacement belt for a Porter Cable Model 361 Type 6 belt sander 3X24. What is the trick to get the belt on? I can not get it around the driver gear and the driven pulley. Do I need to take the whole thing apart or is there an adjustment that will allow me to put the drive belt on?
  • 4 more comments
  • jason_stroll May 28, 2009
    I have tried that but the belt gets so tight it feels like it's going to snap. So, I didn't force it. Is that the only way to put it on or is there a way to release one of the gears?
    I think you might have misunderstood my question. I am trying to replace the drive belt (inside the cover plate) not the sanding belt.
    Okay, thanks for all the help. I'll try rolling it on.
  • Samuel Charles Spriggs May 11, 2010
    Another thot, if you can't roll it on, is to immerse the belt in hot water for about 30 seconds, then quickly try the roll on method again.
    jmorganti,
    I think you are describing installing the sanding belt. The question is how to install the drive belt.
    jason,
    If you can get the edge of the belt on the small gear, I don't think you're going to snap it by using that method ("rolling" it on).
    I think the trick is to get as much slack as you can in the belt on the side opposite the way you are rolling the little gear.
    The notches in the belt will grab the spline on the gear and cause it to tighten even when the belt is long enough to go onto the gears. It has to be "kinda finessed on".
    Charlie
    I looked at the schematic of this sander. It looks like all the rest of them to me.
    Have you tried putting the belt on the large gear first, then putting the edge of the belt on the small gear and turning the small gear? This usually "rolls" the belt into place.
  • 864 Answers
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
Posted on May 28, 2009
    President:
  • 1,489 Answers
If you don't mind, let me know the outcome.
thanks...
Charlie
I have a Porter Cable 2'' A-2 belt sander and need
you can buy that gear from ereplacementparts.com you will need the type number off the tool to make sure you order the right one, they cost around 25.28 and for a type 2 the number is D839309
Sep 10, 2011 | Porter Cable 363 4" X 24" Belt Sander
I need to replace a drive belt on a porter cable belt sander model 371 and am having difficulty putting the new one on.
I believe you push the front roller until it clicks, then slide old belt off. Then push to release lock
Jul 14, 2011 | Porter Cable Garden
I have a Porter Cable Model 371 2.5" X 14" Belt Sander. I broke a belt, when I did it jammed and also broke a rubber sleeve that covers the Drive Wheel. I have yet to find this rubber sleeve in any part...
Unfortunatly that sleeve is not available, you will need to purchase a whole new drive wheel. The Drive wheel is $9.66 from DeWalt Service Net. Porter Cable, Delta & DeWalt are all owned by Stanley Black & Decker, you can contact DeWalt Factory Service for all parts. 1-800-4-DeWalt You can order the parts on-line, over the phone or though a local service center. The website is www.dewaltservicenet.com Below is the parts diagram for your sander. The part number for the drive wheel is A16439
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=65594&typeId=15450&documentId=34604
Oct 10, 2010 | Porter Cable 371K Factory Reconditioned...
I need a new belt for my porter cable 4X24 inch belt sander - model 362 - type 6 whisper series
I have had the hardest time trying to find a belt for mine.
I've made do with a 3 x 24 without any turmoil
I take it you are having similar problems
Mike
Aug 21, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Replacing sand paper
Look on the side of the tool between the guide and drive wheels for a lever
Loosening or disengaging this lever will take the tension off of the belt so that it can be removed
If there is no lever, there will be a tension know on the front of the tool that you can loosen to remove the belt
Jul 05, 2009 | Porter Cable Tools & Hardware - Others
I need a switch for my Porter Cable Heavy Duty Belt sander model 361. PLEASE HELP ME LOCATE A SWITCH.
You didn't specify what type but I looked at a type 7 or so and the switch number is 697452 and list is 14.00. You should be able to buy that online or I would suggest if you have an electrical supply house in your area taking that one and matching it up, there is nothing special about it other than size, BUT make sure that they get one for the proper amp draw which is listed on switch. Let me know if I can help further
Feb 22, 2009 | Porter Cable 361 3" x 24" Belt Sander
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 361 3" X 24" Sander Logo
556 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
