Question about Epson Stylus C86 InkJet Printer
EPSON STYLUS C86
Hello
I just got a use epson C86 printer.I put in my printer software, it load up, but when I went to print, no print on the paper. The ink show half full.
Thank you
Raymond Simmons
raymond.simmons@cc.cravencc.edu
  • 55 Answers
Let's Try first if it can print without using your computer just to check if printer is working fine by itself.
step1
Make sure its not connected to the computer and there is paper loaded on the printer. Turn off printer, press and hold paper button (middle button) then press and release the power button (right button). If you can see a flashing green light release your hold on the paper button.
If it prints by itself good go to step 2 if not check what lights do you see. Solid red light on ink light (tear drop button) means one or more inks is empty. Epson printer will not print if one or more ink is empty.
step2
Check if computer can detect printer goto start/control panel/systems/ click on hardware tab and click on device manager
On device manager click on Universal Serial Bus controllers press on the "+" sign check if there is USB printing support on it
Check if there is a mark (ie. ?, !, red x mark). If none good there is no conflicts. If there is a mark right click on USB printing support and click on update driver and install recommended
Posted on Oct 09, 2008
Why the epson stylus C86 dont print nothing?it makes noise like its print but on the paper nothing
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
You can run a printer check to determine whether a problem comes from the printer itself or some other source.
1. Make sure both the printer and computer are turned off. Then disconnect the interface cable from the printer.
2. Make sure letter-size plain paper is loaded in the printer.
3. Hold down the paper button, then press and release the power button. Continue holding down the paper button until the green power light starts to flash, then release it.
If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the ink button on the printer for three seconds. (This only works when the red ink light is off.)
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson Stylus C86 InkJet Printer
Put in new ink cartridge and every other line is 1/2 readable?
Epson's software will let you clean your print head. Inkjets have a problem with drying out and clogging. Access your Epson monitor software and clean the print head.
Sep 15, 2009 | Epson Stylus C86 InkJet Printer
Epson r230 general error
Blink alternately or not? If alternately, the message is not "general error". but "service required" It's true to reset waste ink counter. But, i think it's not service required. when trun on printer ready? But when start to print red lights blink at same time? Problem with chip at ink tank. Check connector at chip and at head carriage. It's may be dirty, and not good connection. try to use another chip.
Jun 22, 2009 | Epson Stylus C86 InkJet Printer
Communication Error C86
Hi
Try to uninstall and reinstall the software from this link click HERE
Hope this helps
May 13, 2009 | Epson Stylus C86 InkJet Printer
C86 Epson printer will not print.
Please see your user manual for the meaning of the various light combinations, or if you don't have one, see:
http://files.support.epson.com/htmldocs/sc86__/sc86__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
and look at "Diagnosing Printer Problems".
BOBDOYLE - can you confirm which red light is flashing? If it is the ink light, see the instructions for changing ink cartridges. If it is the paper jam light, check for a paper jam. If you still cannot fix it, come back with a new comment giving any further information.
If this advice was helpful, please rate it.
GUESTS - you both have quite different problems to bobdoyle. If you require specific further help, please register and post a separate request for help.
Feb 05, 2009 | Epson Stylus C86 InkJet Printer
My epson stylus c86 is locked flashing paper and ink red lights. The down load from epson to reset the counter for the ink foam,says the printer is no on or have a problem,
TONYCRVTTE and NOVGUNS
Have a look at:
If it's a paper jam, look for and remove paper in feed system. If no paper, is the print head properly parked under the right-hand end of the cover? If not, you may have stuck or detached parking mechanism. Come back to me if this is the case for further help.
If it's "internal error", it usually means the waste ink pads need changing. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C86 Service Manual". You will often find them
for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Please rate this advice.
Jan 13, 2009 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 won't print
You have to check if the waste pad of the printer is full. If this occurs, you have to call a technician to replace it (or yourself can do , if you are able to). With the waste pad replaced, you can reset the internal counter with this program :
This program can show you if the waste pad is full, or what problem is happening.
Apr 07, 2008 | Epson Stylus C86 InkJet Printer
Printer not printing
I hate Epson. Had problems with Stylus C82 and now my replacement Stylus C86 has given me nothing but trouble.
I've just replaced all four ink cartridges and now when I print I'm only getting blank pages. I uninstalled, reinstalled, and nothing is working. I even called Epson, twice, only to be routed to the Phillipines where neither person was very helpful, in fact, had a hard time understanding their English. So this is what I;m going to do. I'm taking this bloody Stylus C86 outside and smash it with a hammer..then I'm going to buy a HR Printer...and if anybody from Epson reads this...good luck...your products SUCK!!
Nov 04, 2007 | Epson Stylus C86 InkJet Printer
Epson Stylus CX4600 printer/scanner
It sounds like the nozzles may be blocked, if it has been left for 10 months will no ink - It will have dried up. It is probably worth you running a head cleaning procedure which can be done using the Epson software. Please let us know if this helps. Thanks Daniel
Mar 13, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus C86 InkJet Printer Logo
180 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
