My AKAI DLP is 4 years old now picture does not come on do i need a new blub?
I have the same TV. On the back of the TV there is a square panel. Unscrew the six screws (the panel is on the opposite side of the inputs, I used needle nose plyers) after you take the panel off (make sure the tv is unplugged) you will see a black "housing" with two stainless steel screws. Unsrew those two screws and pull out the housing. there will be 4 screws to take off (uses a special tool called a T-8 TROX screwdriver and replace bulb. BE CAREFUL for this TV there is 2 different bulbs. If your serial number ends in a J you need a different bulb then if it ends in a Z (serial number is on the back of the tv in the middle) I recommend shopping www.nextdaydlp.com as they clearly label there bulbs, plus they are cheap!
