Question about Britax Teutonia Y2K2 Jogger Stroller
Teutonia replacement part for wheel
Where can I find a pin/spring that holds to wheel to the axis? Without this part, the wheel comes off the teutonia stroller axis?
2 Suggested Answers
SOURCE: Instruction manual - Teutonia Y2K jogger
the set is taken out the normal way push down on the sides there is a tab that sticks out for you to do this then pus seat forward it's now out just turn it around and slip back into place it will click in. baby is now facing you!
Posted on Jun 26, 2008
SOURCE: Britax Teutonia Y2K2 Jogger
All manuals back as far as 2005 are available to download on website. Hope this helps!
Posted on Apr 24, 2009
0 characters
1 Points
Pins come out of front wheel while running
hi,i got same problem,how did you fix it?
Oct 18, 2012 | Baby Jogger 2 Stroller
I have a Baby Jogger City Select (manufactured 10/2010) and have an issue with the handbrake. When you pull the lever on the handle bar the cable, which runs to the rear axis, pulls out a little metal bar...
I did not have to disassemble at all. Thanks to your comments. I just took off the wheel with the stuck pin; gripped the pin with large pliers and a tight grip; pulled slightly outward while turning pin. Did this a couple times and the pin shot back into place!
May 07, 2011 | Baby Jogger 2010 City Select Baby Stroller...
How can I fix a bugaboo rear wheel
Need to know what's wrong with the wheel? If it needs a new inner tube it's a 12.5 x 175-2.25 your local bike shop can get you one. This inner tube many strollers examples are the Quinny Buzz 3 and 4 (rear), Quinny Speedi SX (rear), Quinny Freestyle, Maxi Cosi Mura 3 and 4 (rear), Bugaboo, Phil and Teds E-type, X-Adventure, Joolz Bloom, Joolz ZZZ One, Joolz Day, Teutonia, Easywalker, Cossatto Mobi (rear), Baby Jogger City Classic Single (front and rear) and Double (rear) and many more.
Nov 26, 2010 | Bugaboo Frog Stroller
How do I fold my jogger (The Twinner II-16). I bought it used without a manual. Can manuals be located on the internet? Thanks
There are 4 pins that need to be pulled. 1st Flip the stroller over and remove the 2 back wheels...sqeeze the metal piece by the wheel and pull the wheel straight out. Pull the 1st 2 pins, they are between the back wheels and the front wheel, on either side. The bars these were holding in place will swing up. Then pull the 2 front pins (by the front wheel) and flip the front tire up. The front wheel also comes off but isn't neccesary.
Sep 15, 2010 | Baby Jogger City Twinner Stroller
May 27, 2008 | Britax Teutonia Y2K2 Jogger Stroller
where can i get a another instructions manual for the teutonia y2k2 jogger???
Feb 19, 2008 | Britax Teutonia Y2K2 Jogger Stroller
Lost instructions
Try pulling back any sleeve around the wheels, and look for a spring loaded pin, generally the wheel will pull off when this is depressed.
Jan 27, 2008 | Baby Strollers
Quinny zapp back wheels - help
Yeah the grey pin was stuck in. I noticed a small screw at the back of the hub which when removed releases a spring loaded black plug. Be careful when you undo the screw, otherwise you might lose the spring and the plug as they can fly out suddenly. Once you have got the black plug and spring removed you can stick a screwdriver in and pop out the grey pin on the opposite side of the hub. I then re-assembled the spring and black pin and job done the wheel didn't fall off again.
Jan 18, 2008 | Quinny ZAPP Stroller
Britax Teutonia Y2K2 Jogger Stroller Logo
372 people viewed this question
Top Britax Baby Strollers Experts
Stephen Faulkner
Stephen Faulkner
ray gallant
Tom Chichester
Are you a Britax Baby Stroller Expert? Answer questions, earn points and help others
