Question about Canon EOS Rebel XSi Digital Camera
Canon XSi tells card write protected but card is unlocked
Camera was working fine last night. When turned on this morning the camera's LCD displayed Card Write protected. I took the sd card out and it was NOT on lock. put it back in and attempted to take a shot and it displayed again. I tried a different SD card and it displayed the same error. I tried reformatting both of the cards and then attempted to shoot with both cards and again it displayed that there was a card write protected. I assumed that it was the cards, but wanted to be sure so i took both cards out and put them in my friend's nikon D80 and they both worked fine. I put my cards that i thought were giving me the error into his D80 and it too worked fine. I put his card into my Canon XSI and it displayed the same error. Last thing i tried was resetting all settings back to normal and then shooting. Again.. Same error. Please advise. card is not locked but still the camera says is a protected memory card... please help
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
Every time I turn on camera,it displays CARD LOCK? and will not work
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 05, 2014 | Vivitar Cameras
Canon powershot sd 1000, memory card not detected
Please try to copy all the contents of your SD card to your computer. Then format the SD card and try it again on your camera.
If it still can't be detected, try another SD card.
Aug 08, 2012 | Canon Cameras
How do i sent my canon e0s card write protect to unlock
Look at the memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 01, 2012 | Canon EOS Rebel XSi Digital Camera
When I turn on my camera to shot a picture, it will not let me. Instead a screen pops up that says "card write protected." What does this mean?
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If this doesn't do it, try a different card.
Nov 03, 2011 | Canon EOS Rebel XSi Digital Camera
After a birthday dinner, i plugged my sd card into my computer to upload my pictures only to find that a couple of them were corrupt and couldn't even be viewed. I put the sd card back into my Canon...
Most probably the problem is in SD card. Please try a different card to check. Also perform scandisk on this SD card to check for errors.
May 14, 2011 | Cameras
The card is in write-protected mode. How do i fix this?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 08, 2011 | Canon EOS Rebel XSi Digital Camera
Card error
The SAME thing is happening to mine as of yesterday.. I uploaded pics no problem yesterday morning, took more pics last night and then when I went to plug it in.. says card error. Tried other cards in my camera, its saying the same AND this card will no longer work in other readers.. Heeelp please!
Oct 30, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
Camera is stating No Card when there is an SD card in camera
camera sd card board is faulty you need to relace new sd card board.
Jul 09, 2010 | Canon EOS Rebel XSi Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
364 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
