Question about KitchenAid KCO1005OB 1400 Watts Toaster Oven with Convection Cooking
KitchenAid toaster oven Mod# KC010058
Brand new, got as house warming gift.  Worked for a while then nothing. It will not heat, broil, toast or anything. The red on light does not light up.  Electrical outlet is fine and working.  Ubfortunately, I do not have any manual or other paperwork for the appliance but it is brand new.  Is there an internal safety switch or circuit breaker?  How about a safety switch for the door?  Any help will be appreciated.
Jim
  • 5 more comments
  • notoast Dec 14, 2007
    We have been using the toaster oven for about 8 months (maybe once a week) and just this week it stopped working. The light will not go on and it doesn't broil, toast, warm or even heat up when I turn the timer on. I tried unplugging and tested the outlet but no luck.
  • Anonymous Jan 02, 2008
    It happened to two kitchen aid toaster ovens that I got. I am trading it in for something else. They really need to do something about this because they are well-respected. I checked on another website and saw tons of reviews for people who had the same exact problem.
  • Anonymous Apr 22, 2008
    Same problem as the others, no red light and no heat. The bi-metal overtemp thermostat switch failed. I tried to contact KitchenAid and purchase another switch but they said it could not be done. They do not service toaster ovens, only warranty if it's less than 18 months old and you have a proof of purchase. They offered to sell me another unit for a reduced cost but I declined since I have only had mine for 14 months and though I was buying quality. I didn't have my receipt for proof of purchase so no replacement for me. I will not buy another KitchenAid product again.
  • Anonymous Dec 12, 2008
    Same problem here. Toaster overn just quit working! It is just over a year old.
  • Anonymous Dec 25, 2008
    Just goe KA toaster oven, when I plugged it in nothing happend! The red light did not turn on and the taoster oven is not heating up... I am super disappointed, I usually love all KA products. Will be returning this to the store and not buying another KA toaster oven,,,,
  • mobyfresh Mar 15, 2009
    this is my second toaster oven of the same model. Got the first one last june as a present, was broiling a piece of fish and it just stopped working. It was only 2 months old. Kitchenaid replaced it with the same model and have been using it without a problem for several months. Again was broiling something and it just died. The only thing working is the timer ticking away.
  • alafrantz May 11, 2010
    JimiJam soultion is correct I tested this by bypassing the switch.
    I was hoping he could identify were the solder drop goes.
    Is is on the metal part of the pin or the top of the pin that makes the contact (the part that looks to be ceramic.
The overload switch is located above the theromostat.To check it put a jumper across the switch and plug the unit in. If the switch is bad you will now see the red light on and the oven will work. Take the switch off and gently pry the 4 posts back. Remove the pin, gently put it in a vise and put a drop of solder on top of the metal cap. Put the switch back togther, install it and you should be back in operation.
Posted on Mar 13, 2009
Though this is a generally good idea for a fix, I am not sure you should just do this solder idea if you don't know what you are doing. The solder should be the proper type to melt at the right temperature (206C). As far as I can tell, there is no bimetallic function here. It is the solder that is the only line of defense to stop damage from overheating. Since all solder seams to melt at around this temperature, you should be relatively safe as long as it melts below 206 C. However, I am guessing KitchenAid doesn't sell this part because if it failed, there must have been some cause of overheating. Unless that root cause is fixed, they probably don't want people to keep running the thing. It could be dangerous in an extreme case. I.e. The switch may not have failed, it may be doing its job just fine and your toaster may have another problem. Just randomly putting something in there to hold the pin up is equivalent to someone replacing a fuse with a piece of tin foil; it is very dangerous. So, yes it can be done, but make sure you know what you are doing. THis is basically a calibrated switch put in there for your safety.
Posted on Jul 25, 2009
Using this solution:
the problem is the current overload switch is faulty, the bi metal spring should heat up and break contact with the pin. this does not happen, the heat builds up and the solder holding the pin in place melts away and the pin falls down. this breaks the contact and no electrical current will result.
I opened the overload switch and put a solder drop on the ping. Works like a charm!
Thanks FixYa!!
Posted on Jun 06, 2008
Just take the timer out of the circuit. when the oven is plugged in it is on. when you unplug it, it is off.
Locksmith
Posted on May 18, 2010
  • 3 Answers
Although it seems like an easy repair I have trouble following it. When I took the switch apart, the pin has a metal head on the bottom and a pinkish rod touching the bi-metal spring. The question becomes - where does the drop of solder go - at the end of the pink red so it is connected to the bi-metal spring or at the metal base so it is connected to the metal assembly with the 4 prongs?
Posted on Dec 19, 2009
I have the same problem. Fixed it with a drop of solder but it didn't last. Went to fox it again and lost the pin. It dropped in shop and no luck finding it. Where can I get a new overload switch?
Posted on Jul 10, 2009
Contacted KitchenAid and got a brand new one shipped to my door with no charges. I just had to put the old one in the new box and return via UPS all postage paid. Great PR and customer service. The new one works fine.
Thanks for the response.
Jim
Posted on Jan 11, 2008
The problem is the current overload switch is faulty, the bi metal spring should heat up and break contact with the pin. this does not happen, the heat builds up and the solder holding the pin in place melts away and the pin falls down. this breaks the contact and no electrical current will result.
Posted on Jan 10, 2008
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
Where do i find a replacement knob for timer on the kitchenaid toaster oven model # kc010058
I contacted kitchenaid at 1-800-541-6390 and they graciously sent me a new one at no cost.
Dec 01, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
KitchenAid KCO1005OB 1400 Watts Toaster Oven with Convection Cooking Logo
3,507 people viewed this question
Top KitchenAid Toaster Ovens Experts
Marvin
Marvin
Think Crucial
Think Crucial
Tom Chichester
Are you a KitchenAid Toaster Oven Expert? Answer questions, earn points and help others
