The blue screen continues to repeat and wont boot up entirely
SOURCE: Lenovo S series ideapad will find my dlink router no network addr
Generally if you can see the D-Link then everything is trying to talk. Would have to know if the d-link is new out of the box or is part of an existing setup. If the d-link has been part of the network I would suggest that you don't have the security settings correct. If you right click on the network icon and look at the send received numbers. If received is zero then your problem is you don't have the security key (WEP or other type)) setup. If you are getting recieved numbers you may not have the DHCP setup in the d-link. DHCP assigns the numbers to the computer but the d-link has to have this turned on in some models others it is by default.
If both your laptop and dlink are not new and specifically about a year old then I would also suspect that the dlink has died or is dieing on you. If you have had periods of disconnects or slow jerky network acess then these are signs of the dlink having problems. The wireless part tends to go after a year or so while the wired portion probably still works. When they go they are annoying as they work then they won't and so on.
That is you next step to try is to plug in your laptop direct to the wired connection on the dlink to test if the problem is the wifi portion of the dlink. If it connects your problem is the wifi and you probably will have to replace the unit. Next plug it into the cable modem and see if the problem was in the dlink itself.
SOURCE: Lenovo X60 Laptop blue screen
Try to go into safe mode by pressing F8 as soon as you turn on the laptop.
If you get into safe mode then go into system restore and choose a date when the laptop was working properly. Let it rollback to that date and reboot the computer and let it go and see if it goes back into windows.
If you get a blue screen even when trying to go into windows then the operating system is corrupted and you'll need to do a factory restore on the laptop, meaning the hard drive would have to be wiped out and the operating system put back onto the hard drive.
SOURCE: Lenovo IdeaPad Y530 - 40512SU screen is dark
Have you installed the Lenovo EnergyCut drivers? Without it, laptop may not work properly and turns extra hot. Try letting it cool down before you try again.
SOURCE: Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
SOURCE: Lenovo Ideapad- screen has begun
The screen control board coudl be goign bad. The heatsheild in the screen could be the cause. The cable that sends the signals to the screen could be bad. The graphic chip could be overheating or could be starting to detatch from the motherboard.This is not something you should look at yourself. It is best to be taken to a technician.
