Van quit running with the pump seeming still to be strong.have replace crank sensor and made sure fule is flowing. all fuses r good and new battery.i have even did a secerity reset and it still wont fire, not even on off of starting fluid. plz help
Something in your ignition system or circuit must have quit. The code does not seem to be related. Have you checked for spark?
There is a good read here on the code-a complete run through of what to check.
.there is a good read here on TTT
My internet connection is to blame. Here is that linkhttp://www.obd-codes.com/p0463
SOURCE: car wont start
check your fuel pressure it should be 35 psi .fuel pump relays dont go out but check all fuses with test light there is a fuel injector fuse but most likely problem is your fuel pump!
SOURCE: 1994 pontiac bonneville fires up but stalls imediatly
WOW a 94 with 46K on it thats rare. Your computer may be bad it sends the pulse to the injector.
SOURCE: 94 pontiac transport no start
some of those vans came with an anti-theft passlock system, it's a small chip in the key-- if equipped, the sensor in the ignition lock cylender failed alot with the early systems, with similar symptoms
SOURCE: 04 Pontian Montana DVD, dead battery
sound like a fault in dvd player.its running battery down.have dealership check it out.sound like a electrical problem.
