Question about Zebra Eltron TLP 2742 Thermal Label Printer
Zebra TLP 3742 not printing
My Zebra TLP 3742 is printing continously when i want to print,at times it is not printing at all.How do i reset this printer or how do i calibrate it?please help
SOURCE: Printer issue in printing
I was told by Zebra tech to attach it with a parallel cable, click on Start, Run, type in CMD and press enter. This takes you to a DOS prompt. type in the following:
cd\ (enter)
ECHO O>LPT1 (enter)
ECHO ^default (enter)
ECHO ^default>LPT1 (enter)
Make sure you follow the capitalization exactly.
Posted on Dec 04, 2007
IrishDruid
  • 2712 Answers
SOURCE: Zebra Printer TLP 2844-Z - Will not print from application - prints SM 10 53 4D
Hold the feed button while turning on the printer. After a config label prints, turn the printer off and then on again, and try printing again.
Also, make sure the lid is closed far enough to engage the lid sensor. If the red light comes on again, press down a bit on the lid, hit the feed button and try to print again.
Posted on Oct 23, 2008
  • 5 Answers
SOURCE: Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Posted on Dec 05, 2008
  • 185 Answers
SOURCE: how to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
Posted on Dec 20, 2009
ozztech
  • 285 Answers
SOURCE: I have Zebra tlp 2844
So you have Zebra LP2844 or TLP 2844?
try diferent driver and print test page
www.seagullscientific.com
Posted on Nov 25, 2010
I have wristbands that are continuous without sensing mark. can i set where the print area beings and ends for each band in continous mode on zebra tlp 2824 printer
Go to "Printer Settings" and set the size/width/start/end. There will be numbers in MM that you can set everything up by.
Nov 26, 2013 | Zebra TLP 2824 Printer
Zebra TLP 2844-Z appears to print from the iSeries/AS400 but nothing prints no error message Set up same as other Zebra printers that are working printing bar codes
check the connection configuration (if is com port, check speed, flow control and others)
Try to install locally with segull drivers (www.seagullscientific.com) if you need, reset to factory defult. print a test label from the driver. if is comunicate, is not printer problem, is connection problem with your software.
Aug 17, 2010 | Zebra TLP 2844-Z Thermal Label Printer
MY ZEBRA TLP2844 print a symbol...
de-install then re-install the printer driver.
also if it has multiple interfaces (such as serial and parallel) be sure to load the appropriate driver.
Nov 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Oct 23, 2008 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2742 not printing
Go to printer properties, advanced - tools - commands
and enter: ^DEFAULT
This command reseys the prntr
Cheers
Mar 17, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Eltron TLP 2742 Thermal Label Printer Logo
135 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
