Question about Akai PT46DL10 46" HDTV-Ready Television
How to change out blub
I need to know how to replace the blub for a Akai DLP TV
    Problem Solver:
  • 15 Answers
Panel on the back of tv, opposite side of inputs. 6 screws takes a special screwdriver. I used needle nose plyers. once in the back, unscrew 2 stainless steel screws to take out black housing. www.nextdaydlp.com has your bulb. make sure you have the serial number off the back of your TV at the end of your serial number you will find either a Z or J. DONT GET THE WRONG BULB! taking the bulb out of the housing is different. you can either take a drill with a small bit to get the nuts out, or purchase the screwdriver called a T-8 TROX screwdriver.
Posted on Jul 01, 2009
  • dreamteamfou Jul 01, 2009
    you can use normal screws after the special ones are out if you are that nutsy
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
Samsug tv dlp how to ck the color wheel
Take a good look at the wheel---if high pitched or fan like sound suspect it-----if any segment missing it must be replaced
Oct 23, 2012 | Televison & Video
Akai 55 inch dlp Tv
What is the problem of your
akai 55 inch dlp Tv?
Dec 23, 2011 | Akai LCT2715 27 in. LCD Television
Need help with blub
Try You Tube,type in ur DLP tv model mnuber,and bulb replacement.There will have a tutoring video how to replaced ur DLP tv model of bulb.
Apr 27, 2010 | Samsung HL-P6163W 61" TV
Dlp tv has lines across the tv its a 61 inch dlp akai tv just want to know why it has blue lines across it ...... ??? please help??
You have a bad light engine. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the generous rating!!!!
hardrocko
Apr 27, 2010 | Akai PT61DL34 Television
Hi I have TV AKAI start projecting a red
rear projection tv can be crt or dlp, if crt, try to adjust red color using the customer convergence feature, you will find it in the customer menu usually under advance feature or video settings, some tvs will just give the convergence caption right on the menu listing. If this does not help then the tv might be in need of some convergence circuit repair, probably one of the power outs is damages and needs to be replaced. If it is a dlp if the red shade extends all over the screen or located in a certain area of the screen then i would have the tech check for light engine trouble, this is a common problem on some dlp systems.if i answered your question satisfactorily please leave your positive feed back. thanks
Aug 26, 2009 | Akai Televison & Video
Good sound no picture
I have the same TV. On the back of the TV there is a square panel. Unscrew the six screws (the panel is on the opposite side of the inputs, I used needle nose plyers) after you take the panel off (make sure the tv is unplugged) you will see a black "housing" with two stainless steel screws. Unsrew those two screws and pull out the housing. there will be 4 screws to take off (uses a special tool called a T-8 TROX screwdriver and replace bulb. BE CAREFUL for this TV there is 2 different bulbs. If your serial number ends in a J you need a different bulb then if it ends in a Z (serial number is on the back of the tv in the middle) I recommend shopping www.nextdaydlp.com as they clearly label there bulbs, plus they are cheap!
May 28, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Akai PT46DL10 46" HDTV-Ready Television Logo
134 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
