Question about Compaq Presario M2000 Notebook
Which port to use for internet access?
Have a hand-me-down M2000.  Have no manual.  Have red cord and blue cord plus black power cord.  To connect to internet, which port do I use .  Assume red cord is the one to use.  Assume blue one is to hookup to printer.  Just no sure.  Thanks, Bruce   drykilnbruce@yahoo.com
    Scholar:
  • 155 Answers
You can download the manual from here http://h10032.www1.hp.com/ctg/Manual/c00563764.pdf
Usually the Blue cable is a USB cable goes to the printer while the yellow cable is the network going to Internet.
See the picture and connect the  printer  in position 6 and Internet in position 4.Which port to use for internet access? - a38b58b.jpg
Let me know if you need more help.
Posted on Oct 22, 2007
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
I have the Linksys E2000 Router. I have a Dell Inspiron 5150 laptop. I have followed the CD for set up. I have attached the power cord from router to power outlet. I have attached the blue cable...one...
your enternet port is on the left side of laptop plug in make sure you have disk in now restart your lap top now youll get step by steps of what to do next.
Jan 31, 2011 | Computers & Internet
BACK PANEL OF CAR MP3 PLAYER UNDERSTANDING CONNECTIONS. i'VE JUST BOUGHT A CHINA MADE CAR MP3 / FM PLAYER. IT'S BACK SIDE HAS GOT 2 SETS OF SPEAKERS CORDS. ONE BLACK CORD LOOKING LIKE AV CONNECTION JACK...
from what you describe, the red wire is definately power in to the unit ((+) hence the fuseable linkage). Blue is an odd color in electronics, so if its next to the red it is more than likely return voltage ((-) in DC circuits return voltage is grounded. Typically a head unit will have the wire diagram printed on a sticker placed on top or the back of the unit.
AND FOR THE BLACK CORD, thats for then fm antenna, there should be a cord that looks just like that one behind the unit, only the vehicle end is the male end.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Jun 05, 2010 | Car Audio & Video
I have a three way switch in a lamp, one red wire one black wire and one blue wire coming out off the switch,how do I wire off the switch?
Black is the AC power into the switch, and the others are the switched power leads out. Take a close look at the switch housing and you might see small markings reading L1 and L2 by the red and blue leads.
To wire the switch, use a pressure connector (wire nut) to connect the black lead to the incoming AC power. On a polarized line cord, where the plug has one prong wider than the other, the hot side is the narrow prong. The neutral side, which connects to the white wires from the lamp sockets, is the wide prong, and the cord usually has a ridge molded in.
The red and blue wires go to the sockets. (This kind of switch is usually used in three-socket lamps, so I assume that's what you have.) The red lead should connect to the black wire from one socket, and the blue lead to the black wires from the other two. The usual sequence is power off, L1 (red) on, L2 (blue) on, L1 and L2 on. So as you turn the switch (or press the button in a push switch) you get one light, then two, then all 3 on.
Make sure all your connections are good and tight with UL approved connectors and there are no exposed bare wires, and you should be good to go.
Feb 17, 2010 | Kitchen Appliances - Others
Only the sub-woofer is on , not the other speakers
Did it ever work and then spontaneously fail; are are we starting with a new unit and may not have it set up correctly?
If the latter, see page 5 in the manual on speaker connections...
Connect the speaker cables.
A
Confirm the colors of the tags on the ends of the cords.
B For White tags:
Connect cords to grey terminals.
For Blue, Black and Red tags:
Connect cords so tag colors match the terminal colors.
Cords with white and blue tags are for high frequency.
Cords with red and black tags are for low frequency.
Incorrect connection can damage the unit.
Feb 02, 2010 | Panasonic SCPM29 5-Disc CD Changer
Need to reconnect dryer power cord. Black to
In most cases your black and red wires will be the hot wires and the bare(green) or white will be your ground and grounding wires.
Oct 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Compaq presario m2000 - secondhand
This does appear to have wireless capabilities. there should be a small button to the left of the screen latch which you press to turn wireless on/off when on there should be a blue light that comes on. if you wish to use wireless to access your broadband you will need to have a wireless router / ADSL modem (depending on your supplier) you then configure the settings on the router to access the internet, then you configure the laptop to connect to the router. (there shoudl be instructions on how to do this with the router I hope this helps
Sep 28, 2007 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
