Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I have lost my pin and backup keys + battery dead!
I have replaced the battery's in the safe and the code i set has been enabled, how do I reset a new code to open the safe? I have a Kingavon electronic safe 28. Thank you fr youe help Verity I forget my pin, battery went dead plus lost my keys!
    New Friend:
I got the same problem i lost my key and cant open now
any idea what to do
Posted on Feb 08, 2013
Whats the default code for gordon digital safe box sk#p45981
Posted on Jun 01, 2009
2 Suggested Answers
ekoo
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
To get in my safe i lost the key and the batterys are dead is there any thing I can do to get in my safe
The key slot should have a number stamped near it. Take that number to a locksmith along with the manufactures name and the year and model of the safe. The locksmith can make a new key.
If the safe has a key a paper clip, a screw driver and some patience will allow you to pick the lock. Just apply a twisting pressure on the key cylinder, and rake the pins in the cylinder with a straightened paper clip. If the pressure is just right the pins will line up and it will open. You will still need to have key made.
Oct 05, 2017 | The Home Security
How to open nutool sf5
instructions to reset the combination on a nutool SF5 safe
Open the safe door and press the s key press the 1 key twice then press the red button on the inside of door near the hinges.
you will hear 2 long beeps.
enter your combination up to 12 numbers then press the E key your combination is now set
Feb 25, 2012 | Computers & Internet
I have a safewell safe. Batteries are dead and I have lost my keys. The reference is EX2006029121. ANY IDEAS PLEASE.
I read this elsewhere. it's worth a try...
"I had the same problem, batteries dead and i could not find the keys. I read on the internet that if you get a hairdryer, and heat up the front of the safe where the keypad is and where the spare key goes in this will work, i thought anything is worth a try. So i held the hairdryer there for a bout 15 mins and what happens is the heat slowly boosts the battery life, enabling you to open the safe. You will notice that you start to get a beep noise from the key pad. even though i was getting a beep from the pad it didnt open straight away but after about 10 mins i retried the code and it worked. Make sure you replace the batteries immediately before closing the safe again "
Jan 25, 2012 | Locks & Locksmithing
We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Dec 07, 2010 | Sentry Fireproof Safe
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
I have a digital electronic safe home protection. I have lost my keys and the battery is dead I have had thi safe for nearly 2 years
1) look again for the key
2) call a lock smith
3) drill the lock
these safes arent expensive , cheaper to drill the lock and replace that a lock smith , but get a quote
Oct 09, 2009 | Safe International Digital Electronic Safe...
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Need to reset the electronic code to open the safe.
Apr 06, 2009 | Safe International Digital Electronic Safe...
Blue Hat Bank
Type in the code 1234 ENTER then enter your child's new pin.
Pax, Moncia
Jan 04, 2009 | Blue Microphones Blue Hat Little Shots...
Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool Logo
6,403 people viewed this question
Top Safe International Locks & Locksmithing Experts
Jim London
Jim London
john h
Are you a Safe International Lock and Locksmithing Expert? Answer questions, earn points and help others
