Just a suggestion ... remove the lens, card and battery. Recharge the battery completely. Install the lens, card and battery then do a hard reset...
Hard Reset:
With D40 you need to install the lens, the card and the battery then open the cover under which USB and video sockets are. There is a small button in the hole. Press it with pencil tip or something and the camera will be reset losing all settings and clock time.
As far as I know, the D40 cannot charge the battery via USB like you can with some cameras.
it was working fine, and i had been charging it with the USB cable, it showed it had a full battery, i took it off to take some more photo's and it is died!, i just wondered if you had to unplug it correctly from the laptop, i.e eject it (somehow) before unplugging it, would this make a difference?
maybe it was'nt charging then!
but it was showing the a full battery.
i have it on charge now, so i will see what happens once fully charged!!
Sorry if this sounds a little too basic..but have you checked the battery to make sure it is charged?
