Question about Dell 1700 Laser Printer
Flashing error and toner on Dell 1700 and will not print even after replacing drum and toner this happened before and I found on line sequence of pushing the buttons on printer to clear...but i can no
Dell 1700 I replaced the photoconductor kit and it will not print anything but the sheet stating the printer has sropped because the kit has reeached the end oflife....but thekit is new. it will not even print menu. The error light and toner low are flashing
After replacing fysicalythe photoconductor/imagaging drum, leave the door open. Press and hold Cancel untl all lights flash in sequence to reset the printer. Close front cover.
Posted on May 29, 2009
  • Painesville Oct 07, 2010
    Great answer, simple and clear. Worked first time. Thanks.
  • 10 Answers
You need to reset your drum counter. Every time you replace the photoconductor, the life counter on it has to be replaced. You will need to contact Dell to get these specific instructions.
I have a Dell 1700 printer - it was showing an error and when i pressed the green button it printed a help guide. This said that i needed to replace the imaging drum and it would no longer print until this...
After you replace the imaging drum, you should reset the imaging drum's counter. To
reset the counter, press and hold the Cancel button until all lights flash in sequence.
May 03, 2011 | Dell 1700 Laser Printer
Photoconductor kit? Dell 1700 printer
The photoconductor kit is another word for the drum or imaging drum. All three words refer to the same part.
Here is a link from the Dell site for this model.
http://accessories.us.dell.com/sna/PopupProductDetail.aspx?c=us&l=en&cs=dhs&sku=310-5404
Once you replace the drum, the printer has to be manually reset. If this is not done, the printer will continue to give this print out. By resetting it, the counter is set back to zero. The drum is good for around 30k prints.
From the Online Manual for the 1700, to reset the counter:
http://support.dell.com/support/edocs/systems/1700n/en/index.htm#online_documentation
To reset the counter, press and hold the Cancel button until all lights flash in sequence.
NOTICE: Resetting the imaging drum's counter without replacing the imaging drum may damage your printer and void your warranty.
Jun 18, 2010 | Dell 1700n Laser Printer
Dell 1700 is giving me an error about the Toner. It also prints out a page telling me to replace the photoconductor kit. I have replaced the photoconductor and the toner but it still has the same error and...
The printer has no way of knnowing that you have changed the Photoconductor Unit, unless you tell it (as there is not chip on the Photoconductor).
The Photconductor reset procedure is as follows.
Dell 1700
RESETTING DRUM PAGE COUNTER
1) Leave the power on, insert toner cartridge, and leave door open
2) Press the cancel button and hold till the leds flash
3) Release cancel button and close toner cartridge door
Apr 08, 2010 | Dell 1700n Laser Printer
Dell 1700 laser printer
Call Dell. the 1700 has special reset instructions for resetting the drum count.
Feb 24, 2009 | Dell Office Equipment & Supplies
Is my Dell 1700 Laser Printer photoconductor drum truly fried?
The drum collects used toner for apprx. 30,000 pages. After that, the printer recommends that it be changed to prevent used toner from spilling internally into the printer's mechanisms. The whole photoconducter/drum can be replaced. The new part from Dell is apprx. $50.00 US.
http://accessories.us.dell.com/sna/products/Printer_Accessories/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=310-8710#Overview
You might have reset the "counter" for the photoconducter. Ever  have a water  fillter with an electronic timer? You replace the filter, then you reset the timer? Perhaps you reset the timer without actually replacing the filter. So to speak. :)
The question you should ask yourself is: would I like to spend $30 - $60 [it's cheaper for refurbished parts- Google it] replacing the drum head on a 7 year old printer, or would I rather invest that in a new printer?
Feb 23, 2009 | Dell 1700n Laser Printer
Dell 1700 laser printer has Low toner and error lights flashing
Leave the printer on. Open the front and hold down the cancel button until all the lights are flashing in sequence. Close the front while still holding the cancel with the lights flashing and then release the cancel button. This should reset it.
Thanks
Nov 07, 2008 | Dell 1700n Laser Printer
Dell 1720dn Error and Toner light on
After replacing the drum unit you have to tell the printer that you've done it(it's not smart enough to figure it out itself). Have the front door open and press and hold the Cancel button on the printer until all lights flash in sequence then let go. Then close door and try.
Apr 09, 2008 | Dell 1720dn Laser Printer
1700 Drum Error
hold cancel button down with door open, this should rest it
Mar 27, 2008 | Dell 1700n Laser Printer
Dell printer 1700
First unplug power cord and plug back after 10 mins.
If problem persists, then it is probably a toner error, if the toner is nearly finished. In this case you will see the led flashing only when is printing. Sooner or later the printer will start printing blank or faded pages and you will need to change toner
When is not toner, with same symptoms as above, it can be drum error, in this case printer will keep printing but shows flashing light, at a certain point you will need to change drum kit.
If light flashes and printer does not print, then it is either paper jam inside, or one of errors above at final stage, or one of the door not well closed (check them all), or printer faulty (fuser, heads mechanics etc.), in this last case call service.
Mar 21, 2008 | Dell 1700n Laser Printer
Dell 1700 Laser Printer Logo
813 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
