Question about Toshiba TP61H60 61" Rear Projection Television
No power blinking power light
I tried to turn on my tv and I hear the power click on then click off fast, kind of like click click and then the power light on the front of the tv just blinks. Any idea what this could be?
  • akunaku Jun 09, 2008
    power blinking light, no picture, no sound
  • frod182 Jul 29, 2008
    I have the same problem - When I plug my TV in, it clicks twice and then red light blinks. Can you help?
    Thanks,
  • Toshiba Master
  • 8,617 Answers
You would need to check the power supply and shutdown circuit for a faulty component. There is a manual called Toshiba power spply and shutdown circuitry available for 10.99 at the following link, That manual covers your model as well as quite a few other toshiba models. It gives step by step instructions on what to check, And the site offers ree unlimited support to help you with your diagnosing. They will een email the manual to you instantly if you returnto the site and click thecontact us link requesting that they email it instead of mail it. Here is the link just click on the Toshiba section and go through the pages of listings you will find it listed there.
http://servicemanuals.vstore.ca/
Posted on Jan 22, 2008
Samsung HL-R4266W 42 in won't turn on
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours).
Additionally, have you tried powering the unit using another outlet?
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
May 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
Hello, I have an 56' Mitsubishi 1080I television. Model #55859. We moved the TV across the room last night and now we cannot get it to turn on. All we can get is a flashing green timer light on the front,...
Hi rteague2566,
The flashing light indicates something is wrong. Have you tried pushing AV reset button on the front panel of the TV. You may even try the little pin hole reset by the power button too. I think you may have bumped or, vibrate it to hard in the move and, caused the lamp or lead wires to become lose or, unseated. You may have even damaged it. Did you move this TV when it was still warm? Is the light blinking fast and, can you hear anything going on inside. Usually the DM board fails or, a few capacitors need replaced with this model.
If you still can't get the TV to turn on after the reset buttons have been pushed. Can you read the blink code. It should blink, blink, pause, blink, blink, blink. That would be a blink code of 23. Count the blinks in between the pauses. Let me know what code you get. If it just blinks real fast it is probably the DM. I kind of think you may just need to re-solder the leads. A DM cost about $250 with labor. When you plug back in and turn the TV on, let it blink for a few minutes, it might come back on. I'll wait for your response to give further instructions.
Jan 26, 2011 | Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Powers off red light starts blinking
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.But if you don't hear any strange noises,tv is around 4000 hrs,2-3 yrs it could be time to replace the lamp.The lamp you need is 915B403001.Have a blessed one!
Mar 23, 2010 | Mitsubishi WD-Y657 65" HDTV
My mitsubishi tv turns on for 3 seconds then turns off
Hi,If you hear continueous clicking most likely is t an issue with the ballast which is the board that powers the lamp.But if you dont hear it often and tv is between 1-2 yrs most likely it's time to replace the lamp.
Oct 05, 2009 | Mitsubishi WS-48313 48" Rear Projection...
The screen won't turn on. The tv just clicks and
The power board ic coverter it dead.
U need to replace the power board.
U can go the web and buy this board changes
or get the tv repair man replace part and labor $575.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Toshiba TP61H60 61" Rear Projection Television Logo
289 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
