Question about Panasonic PVQ-M2508 25 in. Combo
Panasonic TV-VCR Combo Problem With Separate VHS Player
I have owned the Panasonic PVQ-M2508 25 in. Combo now for almost 11 years. It has worked well until recently when the VHS player reached the end of its life and stopped working. Being that I previously owned 2 Panasonic VHS players that averaged 10 years of use each, I ordered a refurbished Panasonic VHS player. The problem I'm having now is that both the TV remote and the new VHS remote activate both the TV and the VHS player at virtually the same time and are interchangable. I press ON and both the TV and the VHS player come on. I press ACTION and it goes through the TV actions and then the VHS player actions screen comes up and I am caught in a loop. The only way to get out of it is to manually turn off either the TV or the VHS player. The same is true when trying to adjust color, tint, etc. Is there any way to solve this problem, short of buying another non-Panasonic TV? The old TV itself still works well and is probably worth no more than $25 at this point. Thanks to anyone who is familiar with this problem and has a workaround.
4 Suggested Answers
SOURCE: DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Posted on Dec 25, 2007
SOURCE: have panasonic pvq-2511 tv/vcr and trying to get
numero de parte del selector de canales de televisor pvq2511
Posted on Dec 27, 2009
AJIN G
  • 6694 Answers
SOURCE: Codes to program my Conect it universal remote to both my Insigna TV & my Panasonic DVD player...please help
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily....
http://electro-medical.blogspot.com/
Posted on Jan 07, 2017
Lost remote control
You can purchase another one here
http://www.replacementremotes.com/store/prodthumbs.cfm?ns=1&keyword=PVQ-2511&category=panasonic
Jul 10, 2011 | Panasonic PVQ-2511 25 in. TV/VCR Combo
I am looking for the direct tv remote code for tv model PVQ-M2509 Panasonic Omnivision VHS como.
Hello
Four digit universal remote code for Panasonic TV-VCR combo are:-
0374 0381
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 25, 2010 | Panasonic PVQ-M2509 Combo
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
1/2 Grey Screen when switched to DVD and VHS
First of all,i don't know if you have a combo dvd/VCR player or two separate units.Secondly,please tell me how you connect your dvd/VCR combo OR DVD player and VCR player to your TV.
Solutiondoct
Oct 22, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
VHS Sound - No Picture
try cleaning the vcr with a video tape cleaner
or maby the yellow video output need replacing the cord i mean
Sep 13, 2008 | Panasonic PVQ-M2509 Combo
VCR
Hi dennis176,
Unfortunately, I am not aware of this kind of setup. This kind of solution would not be very efficient. For this to work there would need to be an insert to the VCR (similar to that which is used in a cassette player to convert CD audio) attached to a DVD player. Because you would require a device to play the DVD and send the video/audio to the insert (if it existed) it would actually be more efficient to simply connect the DVD player to the television. The reason inserts exist for cassette players is primarily that it prevents replacement of an entire car stereo system. This is not the case with a VCR. You may consider purchasing a DVD/VCR combo if you wish to maintain the ability to play VHS tapes. If you own a TV/VCR combo, your least expensive option would likely be to purchase a separate DVD player.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 10, 2008 | Emerson EWV603 VHS VCR
PVQ-2510 service menu
If you fix the vertical cirrcuit correctly, there is no need to go into service menu as your vertical should go back to normal. Re-check your work. I remember one cap on this set that gets overlooked all the time so you may want to check it. It is cap C413 - ceramic cap and sometimes it shorts causing a vertical shrinking as you described. Good luck.
Feb 01, 2008 | Panasonic PVQ-2510 25 in. Combo
PROGRAMING REMOTE TO TV
This is a comon problem, look up your code again, but notice combo, look at just the tv, now the vhs, try all of these codes
Jan 06, 2008 | Panasonic PV-C1322 13 in. TV/VCR Combo
DTV remote code
KZXten,
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Panasonic PVQ-M2508 25 in. Combo Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
