Question about Sewing Machines
Machine stopped sewing
I was sewing a piece of fabric and the needle stopped moving up and down. The motor still runs when I use the pedel. When I tried to move the wheel on the side it's extremely tight, and had trouble turning it.
  • 25 Answers
The thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
Posted on Jun 02, 2009
How do I fix the mechanism for the needle. Needle barely moves and will not go down through fabric
If it is a mechanical machine, it most likely needs a thorough cleaning and oiling. If not oiled frequently, the old oil turns to a goo or varnish and prevents the parts from moving freely. Do not force the motor to try to run your machine as it will most likely damage the motor.
Might be best to take it for a standard service.
If you have the patience and time, you can try fixing it yourself:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
In the future, be sure to clean and oil regularly (every 40 hours of sewing, every 6 months if not in use). Use ONLY fresh good quality sewing machine oil, applying 1-2 drops of oil each spot. Consult the owner's manual for instructions.
Dec 22, 2015 | Sewing Machines
Machine stops when needle is moved up or down
Five Common Sewing Machine Mistakes + How to Fix Them
www.tillyandthebuttons.com/.../five-common-sewing-machine-mistakes-...
Sep 23, 2014 - Sometimes the needle will push the edge of the fabric down into the ....also helps stop that problem, too .... makes for very frustrating sewing .... handwheel wont turn and so the needle doesn't move up and down, please help.
Trouble Shooting a Sewing Machine - YouTube
? 2:35
https://www.youtube.com/watch?v=A2QqmEh5qcw
May 25, 2009 - Uploaded by MonkeySee
my machine needle won't go up and down on a white sewing machine. ... won't go up and down it'll go but then it will stop moving after i push ...
Nov 30, 2015 | Sewing Machines
Why is the needle not moving or feeding fabric but motor is running
the needle only sews,, it's the feed dogs in the needle plate area that feed the fabric thru the machine, if the feed dogs are in the up position then the machine will sew, if the machine is not sewing then the feed dogs need to be checked to see if the feed dog lever is up or down, look in the manual to see where the lever is and check it, if the lever up the then feed dogs will need to be checked to see if there is something's wrong with them at a sewing machine repair shop.
Jul 31, 2014 | Janome Sewing Machines
I have a Singer CG-550 and am sewing a heavyweight fabric using needle size 18. The engine whirs but the needle no longer moves up and down once it hits the fabric. It occurred suddenly, and I wonder
The motor may not have enough torque to force the needle through the fabric and back in a cycle. If you continue to force the needle into course material, it could bend the shaft, needle, or cause a misalignment of the needle pitch and direction. It sounds like the machine is a light duty appliance and you cannot force it to do commercial appliations.
Dec 25, 2013 | Sewing Machines
Wheel goes halfway then gets stuck
If it's a mechanical machine, it could be seizing due to old, dried out oil. How long since it has had a thorough clean and oil? If this is the cause, AVOID running the machine until the problem is addressed or the motor can be damaged.
Dec 10, 2017 | Bernina BERNETTE 65 Mechanical Sewing...
The needle on my model 1315 Kenmore sewing machine wont go up and down.
try turning the bobbin in the opposite direction & see if that helps
Jul 30, 2012 | Kenmore Sewing Machines
My machine has a one Step Buttonhole Feature - having problems
Try an Even Feed Walking Foot for more control on thick and quilted type layers
Dec 10, 2011 | Brother CS6000i Computerized Sewing...
Sewing machine motor will not run after attempting
Overload Viking:
The machine has a built in overload protector, if your needle can’t penetrate, it may stop the machine from working for a few minutes. Just wait it will reset automatically. Then, try a Sharp needle (denim needle is ideal) and be sure to Never Never reverse sew on heavy fabric, your needle will bend and hit the needle plate, use the FIX button for knotting (it really does work).
Mar 15, 2009 | Husqvarna Designer I
Sewing machine will not advance the fabric
Have you tried adjusting the tension as you sew?
Use a scrap piece of the same fabric, (doubled, etc to simulate piece you'll be working) and adjust the tension as you sew. Sometimes, that's all it takes.
Jan 27, 2009 | Sewing Machines
Machine is slowing down
Either the machine needs to be oiled or the motor is going bad.Remove the covers and place a drop of oil anyplace that moves and rubs.( The ends of each shaft, the bobbin case area. The needle bar and the joints that allow it to move) Those kinds of places. Also look for thread that may be wrapped around a moving part and remove it.
Check the motor by loosening the handwheel clutch(as though you were going to wind a bobbin) and see if the motor still runs slowly when it is not turning the machine.
sewman7
Oct 07, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
140 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
