Question about HP Compaq tc4400 Notebook
Connecting laptop tip to auto adapter
Hi, I have a auto adapter to power a laptop with different tips. There wasn't a tip that fit my laptop, so I brought the appropriate tip only on ebay. The auto adapter outputs the correct voltage and current (18.5V, 3.5A). I cut the tip adapter from the auto adapter and there are two whites - one red one black. The wires from the new tip I need to add are one black, one white and a much thinner red one. Which wires do I connect?
  • 2 more comments
  • paul860 May 28, 2009
    Sorry, I mis-typed then couldn't correct it. To clarify:
    The car adapter has 2 wires, one red one black. I can set the output voltage between 15-24V.
    The tip has 3 wires - one black, one white, and one red which is much thinner.
    The laptop is a hp tc4400 tablet and needs the inner of the tip to be positive. It needs 18.5V 3.5A.
    I have a multimeter and can check polarity of the tip before plugging it in. I'm assuming one of the three wires from the tip is the earth, but the car adapter has no earth wire.
    Thanks for any help.
    Paul
  • paul860 Jun 02, 2009
    Thanks, I have had some move information from the seller of the tip:
    "I
    am not sure but i have some information, the black wire is connect to
    tip outside, the white wire is connect to tip inside, the thin red wire
    is connect to tip center pin.
    I hope it can help for you."
    The Dc adapter has EWDD8040 on it, don't know if that a model number. So you don't think lean use this tip with this adapter to run and charge the laptop?
  • flubbard May 11, 2010
    I just want to understand the post. Does the auto adapter have four wires (2 white, one red and one black) or two "wires" one white and one black?
    Do you have a multimeter available to you which would be able to check continuity?
    Does your computer call for tip positive or tip negative? (This is normally identified by a little circle within a semi-circle. It will identify whether the tip (inner circle) should be positive or if the sleeve (semi-circle) should be positive.
  • Frank Zhang
    Frank Zhang May 11, 2010
    whats your laptop brand model? then tell you how
  • 191 Answers
You may look the jack(tip) show here:
connecting laptop tip to auto adapter - 1ecfef4.jpg 1) your car adapter, the red color wire is + pole which connect to the hole of jack(tip), the black wire is - pole which connet to outcover metal of the jack(tip). that is very common.
2) your new jack: check as smae as above. usually white color connect to red color, and black to black is ground connect to outcover of tip.
then you need check again the voltage pole, the tip 's hole should be possitive "+" and the outcover metal is negative "-" pole, it is very important.
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
Posted on May 28, 2009
  • 2 more comments
  • Frank Zhang
    Frank Zhang May 28, 2009
    ok, I checked your laptop DC jack input, there are three wires, the red one is signal for laptop battery changing control that could not rid of, so your car adapter could not use to this type of laptop (some laptop with two wires can be used.)
    please take a rating thanks!
  • Frank Zhang
    one more thing:
    if you only turn on laptop without battery charging that your laptop is avalible to use, but you need to make sure the car adapter is a PWM DC regulator, not simple adapter, could you give me your car adapter model brand let me check for?
  • Frank Zhang
    Frank Zhang May 30, 2009
    please take a rating if the solution helped you thanks! keep in touch your comment.
  • Frank Zhang
    Frank Zhang Jun 02, 2009
    I write again that you can not use this kind of car adapert, it will damage your laptop. take a rating please!!!
I tried to do a similar hookup with an old AC power supply and a new laptop jack as described above for my HP/Compaq 8510p. My old power supply ouput wire (laptop side) consists of a coax style two wire arrangment so I hooked up the black wire of the new connector to the outside wire of the coax and the white and red wires to the center wire. Check the voltages and it seemed to work but the CPU is now at 100%! So more work to do.
Posted on Jul 13, 2009
    Scholar:
  • 34 Answers
Unfortunately, I think that frankzjm is right. Your HP laptop is designed to use a "smart" adapter which has the ability to transfer information between the power supply and computer. Basically, it would appear that a different voltage is sent if the computer is both running and charging the battery, where a lesser voltage is sent if only powering the computer. Of course, current draw is varied based upon need through normal electronics. Net effect, it is not a simple plug, give power, and go. The third thin wire is used to communicate between the power adapter and computer. Your car adapter does not have the logic circuits to handle the communication.
Of course, HP does not seem to be very open on how this works (at lease from what I can see). It may be possible to set the power supply for its "opearting only" voltage and trick the control wire (small red wire) by sending the appropriate response to the computer for the adapter to say "I'm OK," though I would need to play with a smart adapter to figure out how exactly to do this. I may take a quick look at one of the HP laptops to see what might be possible, but it may be best to get an officially sanctioned HP car adapter.
- Flub
Posted on Jun 02, 2009
Nc6400 no power on
What kind of adapter did you buy? Did it come with 5 - 10 different tips that you try on the end of the power cord until you find one that will fit into your laptop? If so, no wonder you're having problems, those things will burn your board out. AC Adapters have different power requirements (watts) If you have one that has changeable tips, but the watts are constant, you're asking for trouble. Stay away from those one size fits all Ac Adapter Power Cords
Mar 22, 2012 | HP Compaq nc6400 Notebook
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
Replacing the OEM 18.5 V 3.5 A ac adapter with an 19V 4.74 A adapter for my c551nr compaq, should not give me problems, will it? It should be within spec, hopefully.
Specification of Compaq Presario C551NR AC Adapter:
Power: 65W
Output: DC18.5V 3.5A
DC Connecter (Barrel) :
Internal Diameter: 1.7mm
External Diameter: 4.8mm
But it's OK to use a 90w 19V 4.74A adapter on your laptop only if the connector tip fits your laptop.
Thefollowing three conditions should be met for you to use an ac adpater safely. 1)Output Voltage is within +/- 5% of your old charger's output.
For example, ifyour old charger provides 19.5V, then you can use a charger that provides 20.5Vor 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, ifyour original adapter provides 3.42 Amps, then you can use a charger thatprovides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Mar 29, 2011 | Compaq Presario C551NR Laptop Charger...
I have an Asus Eee and would like to use my Kensington Universal car/air adapter to power it. As far as the voltage is concerned, there is no problem as the laptop runs on 19V which there is a fitting...
Thank you for using FixYa
The physical connection is one thing. If it looks the same it may work, however you might want to know the amps as well, and if the tip is positive or negative. As an alternative the USB adapter may be easier fix and even WalMart has one that fits in the cigarette lighter. My Asus is 19v. 2.1amp, with a tip +.
I hope this was useful and please comment if this was helpful to you.
Mar 02, 2011 | Computers & Internet
I have the targus model APM65US DC auto/air adaptor and various tips. Which tip/connector is compatible with a Dell Inspiron miniu 10. Several look like the right size: #s 102, 104, 206, and 207. Which...
I know this sounds odd but use whichever one is the best fit and works. Also I suggest that you compare them carefully with the original noting differences in length, diameter and construction.
I think you will find that one fits better than the others.If it works and you don't have to push too hard to locate it, and it stays in firmly and connects OK then it will be fine.
regards
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Targus APM65US Auto/Airline/AC Adapter -...
Which Kensington notebook power supply tip will fit a MSI CR600 notebook computer
this is not a supported laptop for kensington power adapters. here is a list of compativle brands and their tip numbers
http://us.kensington.com/html/13675.html
Feb 12, 2010 | ACCO Brands Kensington Wall Notebook Power...
Replacement tips for Kensington 120W AC/DC adapter model 33197
I have the same model adapter for my dell, I believe there is a number on the tip that you need, have you tried ebay for the part they are called 'smart tips'. I think it's a different adapter direct from kensington now, but you can buy them from 3rd parties.
http://us.kensington.com/html/10442.html
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=270522811796
Feb 12, 2010 | ACCO Brands Kensington Thin and Light 70w...
Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Bad decision with new AC adapter for M105-s3004?
if you look at the bottom of the laptop, you,ll see a voltage rated input. i.e 19v-3.1A or similar.
providing the plug fits, and the voltages are the same, you can,t do much damage to either battery or motherboard.
you can buy universal voltage packs now for laptops, which usually run from 15volts to 19-20 volts.
And several different connectors. for different models.
Of course the manufacturers want you to buy theres, and at thier top notch prices, but a replacements every bit as good. although may not be as superior quality.
check the voltage rated input underneath, if it,s the same.
Use it.
Mike @ compurepair.
Feb 25, 2008 | Toshiba Satellite M105 Notebook
HP Compaq tc4400 Notebook Logo
1,062 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
