Question about Pentax Optio S6 Digital Camera
Lots of noise lines in picture screen
My Pentax Option S6 is barely used, and now it gives a lot of noise lines on the LCD screen that will not allow to take pictures after a being on for a few minutes.
I am also getting pictures where the while color is pink.
Could it be a color or light sensor problem? How can it be fixed. Help!
  • 198 Answers
This is a fairly tipical sensor related problem. A sensor CCD or CMOS will use 3 areas of transistors, each of them managing a single elementary color (RGB - red green blue) in order to capture light and compose the picture. The white color is the most complex wave lenght color that a camera can detect. It will record it by combining all those 3 areas of transistors and balancing the amount of red green blue and their saturations to achieve a fairly good aproximation of the white color (thus a white balance model is used to help the camera to easier recognise a white reference point when taking the picture). If the white becomes pink this means that not all of the transistors were used when "reading" the light. If the pictures have too much noise or are difficult to take or see on the display of the camera, it also means there is a problem with the connections between the small transistors in the sensor, more exactly imperfect contact, a smaller control voltage than the minimum required and similar. However, in most of the cases, the sensor itself isn't the problem, that would be the small ribbon like cable connection that links it to the camera's mainboard. If this cable doens't make a good electrical contact with the sensor or with the other end - the mainboard, the signal comming and going through the sensor will be distorded or have missing components. That's the most common situation. Excess moisture, shocks or other factors may damage or weaken the mechanical contact holding the cable connected to it's ends. This should be checked out first, before asuming other causes for the problem. However this requires dissasembling the camera. While the exterior body of the camera may be taken apart by unscrewing some 3-4 screws, the lens assembly is a very fragile component. If it's not handled with care and some specialised tools it will break down, or some small servomotors may become loose. The actual sensor is located inside this lens assembly. It's a very small rectangle shaped object just underneath the back of the lens assembly. The cable running through that area must be checked by in a specialised service center as taking apart the lens mechanism is a very complicated job.
If you need more informations please reply with your questions.  or if you however want to do this yourself (once again, i think it would be very recomandable not to) i can give you some instructions on how to do this.
Posted on Oct 23, 2007
Buying s6 edge plus LCD replacement for phones can be a toss up
Buying s6 edge plus LCD replacement for phones like this can sometimes be a toss up. After installing it and having used my phone (with new screen) for weeks now I feel confident saying mine worked perfectly! It's like having a brand new phone. If you install this screen and are seeing lines on the display it's not a manufacturing problem, it just means the connector is loose/slightly misaligned. If this happens when you first power your phone back up, simply disconnect and reconnect the plug for the display. May take a few tries. With a little trial and error they should eventually disappear once it's properly aligned.
Keep in mind replacing this yourself is doable but will take lots of patience and time. Lots of things to disconnect and reconnect. Followe along with a Youtube tutorial. Samsung Galaxy S6 Edge Plus Replacement Parts Galaxy S6 Edge Plus LCD...
on Apr 07, 2017 | Electrical Supplies
I ahve the pentax optio s6 camera. the camera
Thank you for using FixYa for your problem
Sounds like the LCD is faulty, but there are a number of things that can cause the LCD to play up too
Always check the batteries first (check that the voltage is correct with a volt meter) but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Pentax Optio S6 Digital Camera
How do i focus on close objects like flowers
Go into "macro" mode. Press the button with the picture of a flower and a mountain until the flower appears on the lcd screen.
Oct 12, 2009 | Pentax Optio S6 Digital Camera
Lcd monitor messed up
hello do you still have the monitor maybe i can trade you something for it i can use the parts to fix a unit i have let me know thanks
Jun 29, 2008 | ViewSonic VX2235wm LCD Monitor
No pic framing on LCD display - playback is OK
ON digital slr cameras there is no pic framing on the LCD display.
Apr 25, 2008 | Pentax K100D Digital Camera
Pentax optio s6
perhaps mazzachris would be interested in unloading his/her E10 LCD to me?  My E10 LCD is cracked.
Sep 03, 2007 | Pentax Optio S6 Digital Camera
Pentax K100D DSLR
The interface IC ( between the main CPU and the CCD sensor ) seems faulty . Camera should go to the Pentax agents unfortunately.
Sep 02, 2007 | Pentax K100D Digital Camera
LCD screen 'flicker'
Try setting the video output option to NTSC (if it's on PAL). I know this sounds funny, but I have heard some rumblings about this option somehow creating a LCD flicker. If it doesn't work, I apologize in advance for wasting your time! My camera is on NTSC and I haven't seen any flicker on the file numbers on the LCD.
Sep 19, 2005 | Nikon D2H Set Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Pentax Optio S6 Digital Camera Logo
88 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
