Question about Homelite ZR10926 16 Chain Saw
3300 runs slow
My chainsaw runs slow. This started about a year ago and has gotten noticibly worse. help?
    Sergeant:
    Champion:
  • 226 Answers
This may be due to restricted air flow.there might be a small foam filter were the air mixes it's probably cloged or dirty.clean or replace.hope that does it.
Posted on May 28, 2009
94 Chrysler Lebaron Convertible will not idle but will start and run at high idle.
Try your Idle Air Control Motor. It is located on the throttle body under the throttle position sensor
I have a 93 3.0 that is doing something similar but has not gotten to the state yours is in. If you find anything out let me know. Mine is going to the shop.
Jul 23, 2012 | 1994 Chrysler LeBaron
Hp 2509m screen flicker
Hi Kevin,
My daughter has the same problem with her laptop, do you find that when you move the screen slowly back and forth it either stops or gets worse ?
You will need to take your laptop in to an HP dealer and let them have a look at it.
Regards :)
Feb 06, 2012 | Computers & Internet
Generator is brand new. Was run once. Started on first pull. Hasn't been run for two years. Can't get started. Tried spraying a little starting fluid on air filter, nothing. Help?
The odds are the fuel went bad or water has gotten into the tank during the two years of inactivity. Drain the fuel tank and fill with fresh fuel. Also, you may want to change the spark plug (just in case since it's inexpensive) and the oil. Once these are accomplished it should fire right up. Hope this helps!
Feb 28, 2011 | Garden
Bad gas milage/ moderate low power, suddenly misfiring 3 cylinder
Just start with the cam position sensor - jb weld definately would not work for very long in that heat.
REplace with new - you should be all set. The computer uses the cam's position to time the spark and fuel delivery.
Jul 01, 2010 | 1996 Audi A4
Doesn't want to start at first
Before you crank try and cut key on for 5-10 seconds then off and back on then crank if cranks up then you have a fuel problem. this will allow pump to run and pump fuel up. could be a bad check valve in pump causing fuel to drain back
Sep 05, 2008 | 1998 Jeep Cherokee
I bought the Acer TM2451WLCI Laptop computer about a year ago. Right out of the box it was very slow and it hasn't gotten any faster. Is there anything I can do myself to make it perform faster?
there are several freeware programs that would help. a couple things you can do are to run defrag on the drive...
also go to start.... my computer ... then right click and select properties..... when that window opens click on disk clean up.
make sure all the boxes are marked then click ok and yes to confirm.
Robert
Aug 28, 2008 | Acer Computers & Internet
Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Jun 12, 2008 | Freezers
Homelite ZR10926 16 Chain Saw Logo
83 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
