Question about Asko D1976 Built-in Dishwasher
Installing asko upper dishrack ball bearing kit
Any hints on the best way to install an upper dishrack ball bearing kit on an Asko D1996 dishwasher? have same question for asko 1475 dishwasher.
  • 901 Answers
SOURCE: Asko D1996 dishwater does not turnon.
Check inside the machine for fuse or circuit breaker. Replace or reset. If repeats, you have to contact the service center.
Posted on Apr 15, 2010
Macmarkus
  • 2605 Answers
SOURCE: how do i re-install upper
Welcome to FixYa.
Changing out the upper rack ball bearings...?
Yes there is a trick to installing new bearing & holders. Here's what works for me...
  • remove the rack stops if you haven't already and then the rack itself.
  • With the rack out of the way, remove the bumpers at the back of the rails which will allow you to perform the re-installation.
  • The trick now is to install the balls into the holders and the holders into the stationary part of the rail on the inside wall. The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place. ( I should do a video of this on you-tube with how many I've done and tried to explain ).
  • Once this is done, re-install the back rail bumpers followed by the rack and then finally the front rack stoppers and that should do it.
Hope that explain it for you or gives you an idea of how it needs to be done. Thanks for visiting "FixYa" today for your repair help.
Let me know if you require further assistance.
    **NOTE** I should also mention you want to be sure none of the old 8 balls didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Good luck
Macmarkus :)
Posted on Aug 26, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a ASKO 1796, I love it, but I need to
Welcome to fixya
Here's what works for me, move the rack stops to the left if you haven't already and then the rack itself.
i.e.
and
Now you'll need to remove the bumpers at the back of the rack rail...
i.e.
push down on the bumper as shown
and pull it down and out at the same time...it takes some force as evident by my finger tip ha ha, you can use a small screwdriver...I'm just stubborn.
Now you'll need to slide the rail all the way out as shown, but careful not to let the ball bearings fall into the sump area in the process.
I usually hold the broken piece in place while removing the rail...
...( they come in a kit at "repairclinic.com" under number 1394379 like shown here )
The trick now is to install the balls into the holders first
and the holders into the stationary part of the rail on the inside wall...
The inside wall rail will keep the holders in place as you slide the inside rail into place...this will usually require holding the holder with one hand while pushing the sliding rail back into place...
Thanks for visiting "fixya" today for your repair help. Let me know if you require further assistance.
Good luck.
Regards,
Macmarkus :)
P.S.
I should also mention you as I alluded to, be sure none of the old 8 ball bearings didn't fall down into either the drain pump or circulation/wash pump. This is something I've seen far too often on Asko dishwashers with the end result being a broken impeller in either pump...or both, yikes ! I use a telescopic magnet to fish around as it will be the only object made of metal...unless something else has fallen in the sump well area, it's good to check.
Again, good luck :)
Posted on Jan 26, 2011
Macmarkus
  • 2605 Answers
SOURCE: d1776 asko dishwasher upper basket
Hello, welcome to fixya
i.e.
and
i.e.
and pull it down and out at the same time...it takes some force, you can use a small screwdriver.
Hope that explain it for you or gives you an idea of how it needs to be done. Please take a moment to rate the assistance I provided here today favorable and a brief testimony is also appreciated when providing free solutions.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Posted on May 16, 2011
mc1bean
  • 3053 Answers
SOURCE: Asko D1716 upper rack ball
Hello, dbearden
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Rinse aid dispenser not working
You have to take apart the whole door panel to see what the problem is,.
Jun 07, 2013 | Asko Dishwashers
I have a ASKO 1796, I love it, but I need to change the right dishrack ball bearing cage. Would you explain to me how to put back the rail in the rail support. Sorry, for my english, it's not my mother...
Welcome to fixya
i.e.
and
i.e.
Good luck.
Regards,
Macmarkus :)
P.S.
Again, good luck :)
Jan 26, 2011 | Asko D1796FI Built-in Dishwasher
How to re-install bearings on upper rack on asko 1475
Welcome to FixYa.
Let me know if you require further assistance. Please take a moment to rate the info provided for you here today.
Good luck
Macmarkus :)
Aug 26, 2010 | Asko D1976 Built-in Dishwasher
Apr 14, 2010 | Asko D1996SS Built-in Dishwasher
The upper rack support came apart on my Asko d1716 dishwasher
try contacting a good appliance repair and parts shop......or contact the original manfacturer
Jan 23, 2010 | Asko D1716 Built-in Dishwasher
The top rack on my Asko D1796 dishwasher is defective
call manufactuerer and ask or a good appliance parts and repair they usually are on a spring clip and you just replace the whole roller
Dec 25, 2009 | Asko 1385 Dishwasher
Asko D1996 lights flashing washer won't start
I'm having the same issues. What did you do to solve yours? My start button never lights up! Thanks for your help!
Oct 01, 2009 | Asko D1776 Stainless Steel Built-in...
Asko D1996 Stainless Steel Detergent Door Does Not Open
the pcb will need replacing,the dispenser gets its power from there.
Feb 28, 2008 | Asko D1776 Stainless Steel Built-in...
Upper rack travel sticks and jams.....
you have a bad bearing retainer. you will need to call an asko parts dealer and order 8 upper rack ball bearings, and two ball bearing guides (they are grey plastic and break over time, causing the rack to jam. To replace tham, you must take the upper rack out by turning the plastic retainers on the front of both rails 90 degrees towards the outside of the machine. The slide the whole basket out. Now look at the back of the rails inside the dishwasher. there shoul be 2 more grey plastic retainers with bumpers on them in the rear. These must be pried out wiht a screwdriver (be careful, have cut myself several times on this job till i figured out the best way to do it. cover the bottom hole in the dishwasher with a rag, as you are likely to drop the old bearings when you slide the rails out. Slide out both the rails. Put your new (or old if youve got all 8) ball bearings into the ball bearing holders, then put the holders into the rail thats attached to the dishwasher. slide the rails back in, andthen put all your retainers back in and your rack. you may have to slide the rack in and out a few times before it will center the bearings and work smoothly. Should cost you about $12 in parts. Good Luck!
Apr 17, 2007 | Asko D1716 Built-in Dishwasher
Asko D1976 Built-in Dishwasher Logo
257 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
