Question about The Great Outdoors 3405BG
Need venturi tube w/gasket
On the model 8000 it shows I have to order the burner with the venturi just to get the venturi.
On the model 8000 series it shows that I can just oreder the venturi, which is all that I need.
My question is; can I order just the venturi from the 8000 series and have it fit?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 15 Answers
Which brand is you grill? Some brands you can get the venturi on its own.
Posted on Jan 13, 2018
Why do flames shoot out behind the control knob on my aussie gas grill
More than likely, the venturi valve is clogged by a spider or spider web. You will need to remove the burner to check for this and clear them out. The venturi is the part of the burner that fits over the burner orifice. It may be 2 slots cut into both sides of the burner tube or a series small holes that are not burner port holes.
Hope this helps you and thanks for choosing FixYa. Cheers...
Aug 17, 2011 | Meco Aussie Adventure
I have a 2005 Weber Genesis Silver propane grill. The first and third burners work fine, but the middle burner will not ignite. I have cleaned it and still no flame in the middle. I'm about to order...
Jeanne - Did you remove the burner to clean? If not. you weren't able to clean the Venturi Valve, which is part of the burner. Spiders love to get in the Venturi Valve & build a nest. When that happens it stops the gas to that burner. I suspect, that may be the problem. The Venturi Valve, is part of the burner (the open end part) that's closest to you, when you face the front of the grill. It will look like 2 slots (one on each side) cut out of the burner tube, where it fits over the burner orifice. But, you can't see it, without removing the burner. An old tooth brush works well to clean it.
Hope this helped you to solve the problem. Please let me know and Happy Grilling!!
Jun 19, 2011 | Weber Genesis Silver B Grill
How do you open venturi tubes to clean?
If you remove the burners, the Venturi Tube is part of the open end of the burner that fits over the burner orifice. It should look like a slot on each side of the burner. There's really nothing to open, once the burner is removed.
Hope this helped you and Happy Grilling!!
May 30, 2011 | Fiesta Blue Ember Gas Grill
How do you remove the venturi tubes of a Blue Ember Gas Grill? The manual explains how to clean the venturi tubes, but it doesn't say how to remove the tubes for cleaning. The manual just says...
The venturi tubes are part of the burner. It"s a slot on both sides of the burner tube, where it goes over the burner orifice. You will need to remove the burners to check and clean them.
Hope this helped answer your question.
Apr 18, 2011 | Fiesta Blue Ember Gas Grill
Hi! Hope you can help us--we have a Brinkman 4-burner grill that is about 5yrs. old. Last yr. we started having problems with burner #2 not lighting all of the way and the burners all looked a bit rusty,...
I think you husband is trying to clean the wrong thin. The venturi tube is part of the burner itself. It's the open end of the burner, that has an air intake adjustment on it. It fits over the burner orifice. He may be hitting the orifice, which in fact may be clogged. Remove the offending burners and he will be able to see the burner orifice, which can be removed with the appropriately sized wrench. Once removed try blowing through it. If air doesn't blow through, it's clogged. Clean it with a straight pin that is no larger that the orifice hole. You do not want to enlarge it. Also, the new burners may need adjustment of the venturi for the proper air to gas mixture. Consult you Owners Manual on how to adjust it.
Need an Owners Manual? Go to http://www.brinkmann.net/my_grill.aspx and enter the Model Number of your grill.
Hope this helped you to solve the problem. Please don't forget to rate my response to you. Thanks!
Mar 27, 2011 | Grilling
We're trying to clean the venturi tubes on our Blue Ember FGF50069 gas grill but we don't understand how to disengage the tubes from the burner. Can you help us? Are there any images of the...
The Venturi tubes are part of the burner, where it goes over the burner orifice. You can remove the burner(s) by disengaging them from the burner holder. Which should be at the inner rear of the grill's burner compartment. Then the burner will slide off the burner orifice.
FYI - A couple of years ago, there was a massive recall on the Fiesta Blue Ember Model grill. Don't know if your is old enough to fit that category. So I have included a link to the Consumer reports Website, that liist the Serial Number of those involved.
http://blogs.consumerreports.org/safety/2009/07/fiesta-again-recalls-blue-ember-grill-after-reported-injuries-burns-fires.html
Hope this helped solve your problem.
Feb 26, 2011 | Fiesta Blue Ember Gas Grill
Thermador sgcs365rw - I need to replace the cover for the on/off light. To access it I need to open remove the cooktop but one of the venturi is stuck fast. How can I undo it?
Hello- You got lucky and only have one stuck, unfortunately you will need to order a few more parts. The only way to get the venturi out is to drill it off, drill it down enough that you can get the burner around what use to be the nut portion of the venturi. You will also need to get the orifice holder that the ventrui screws into under the cooktop. These parts are pretty cheap. You could try to put some LIquid Wrench around the ventrui overnight but be sure not to try to force it out too much because the gas supply tube to that burner can get creased if the orifice holder starts to turn... What works best for me to drill the venturi is a countersink, preferably for metal, which has it's largest diameter bigger than the outside of the venturi. Get some cutting oil and start drilling, the ventrui's cut pretty easily but take your time and try not to damage the burner. Once you get down real close to the burner you can try to carefully pry the burner over the remnants of the venturi. Good luck, hope this helps. Best regards.
Sep 27, 2010 | Thermador SGS36GS Gas Cooktop
I am uncertain as to why my barbeque smokes black and leaves a soot film on the whole inside of the barbeque and on the meat that I am cooking. It is certainly a cheap model but I replaced the burner and...
Can you see the smoke coming from the tip of the flame itself? Did you not have this problem before you replaced the burners? If yes to both, then the problem is with the venturi tube of the burner not providing enough air. The venturi tube is the part of the tube where the gas jet from the valve first enters it. There are some holes that control the air/gas mix by their configuration and size. Perhaps you have the wrong model replacement burner. The orifice (very small hole) out of which the gas shoots into the venturi, and the venturi tube itself are both designed slightly differently for use with Propane (bottled) or Natural (piped) gas. Perhaps your new burner has an adjustable venturi to allow more air. If so, remove the rocks so that you can see the flame and adjust by trial and error.
Jun 10, 2010 | Garden
Yellow flame
You may have a rusted, clogged or damaged burner or venturi tube. With a flashlight, check for spider webs, wasp nests or dirt (mud) dauber nests in the opening of the venturi tube where it connects at each gas valve orifice. Clean it out manually or blow it out with air compressor. Make sure the air adjustment opening (on the end of the burner's venturi tube) has not been changed. If it's closed too much, it will be difficult to light and cause lazy yellow flames. If it's not clogged, the burner may just be old and rusted and the burner holes are not allowing very much gas through anymore. It's also possible the burner has rusted so bad, the burner holes have been enlarged, it is falling apart or has cracks along the burner seams. If so, replace the burner(s) immediately. It is unsafe to use. Your local propane co can usually order the parts you need and some will even do the work, if you are uncomfortable doing it yourself. Bring with you the Make, Model and Serial number of the grill, so they can order the correct parts for your specific grill. Also specify whether it's natural gas2_bing.gif or propane.
Douglas
Jun 06, 2010 | Char-Broil CharBroil Master Flame Gas...
The Great Outdoors 3405BG Logo
201 people viewed this question
Top The Great Outdoors Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you a The Great Outdoors Grilling Expert? Answer questions, earn points and help others
