Question about Microsoft Xbox 360 Console
My x-box 360 has no picture when turned on.
I turn my console on and i have no picture.the cable is plugged in correctly to the television. also, when turned on not only is their no picture there is white sqiuggly white lines appear with no sound.
  • kllogan15 May 28, 2009
    red and white audio connections
  • Timothy  Lee
    Timothy Lee May 11, 2010
    what type of connection are you using for the video out? HDMI, HDRGB, or the standard video with the red and white audio connections?
    Scholar:
  • 133 Answers
Your XBOX 360 has a video problem. A different cable will not fix this. It needs to be reflowed. Look online on how to reflow an XBOX360 or send it in for repair.
Posted on May 28, 2009
My xbox 360's wires are all plugged in the correct places and other people can see my xbox profile when i turn my xbox on but on my component source on my tv it says no signal so i can not get a...
If you have the AV cable that has the switch on the Xbox end, make sure that it's in the correct setting. Your cable could have shorted out if this does not work.
Aug 17, 2011 | Microsoft Xbox 360 Console
Xbox 360 elite showing no picture on screen...?? Have tried both HDMI and composite cables. Any suggestions
If the console turns on (you hear fans running and the ring of light is lit), possible issues may be:
1. TV is not on the correct input setting.
2. Graphics card failure (If under warranty, you should be able to send the console to Xbox for refurbishing).
3. Other hardware/software failure.
If the console doesn't turn on (No fans or lights), check the following:
1. Is the power brick plugged into a wall socket?
2. Is the Xbox plugged into the power brick?
3. Is the power brick LED lit? (If you answer no to this, the power brick is likely the problem.)
Mar 10, 2011 | Microsoft Xbox 360 Elite Console
My Xbox 360 will not show a picture you can hear the sound but there is no picture.
1) make sure the video cable is firmly inserted into the back of your xbox 360. Sometimes a loose connection will produce this result.
2) Check the end to your television set and make sure it is in correctly. Is this HDMI ??
3) Cycle the inputs on your tv until it gets back to your xbox 360 and see if the picture appears.
4) If you have this hooked up via HDMI, connect it through another method and go into the video settings in your xbox 360 dashboard and set them to auto detect.
Let me know if this helps.
Jul 28, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
X box 360
Hey tjames2ya,
If your XBox 360 is not turning on, you may wish to verify that the power adaptor is functioning correctly. The power adaptor should have a light somewhere on its casing that shows up green, red or orange when plugged in. Each of these colors is an indication of a different problem:
* Green indicates that power is being correctly supplied to the XBox 360. If the XBox 360 still does not turn on, you will need to contact Microsoft for repairs and support.
* Orange indicates that at least one connection is loose. Making sure that all of the cables attached to the XBox 360 are secure should resolve this type of problem, and allow your console to power on.
* Red indicates that the power adaptor has either overheated or needs to be replaced. If the light is out, this may also be an indicator that the power adaptor is defective, but it may just as easily be a sign that the outlet the XBox 360 was plugged into did not provide enough electricity to power the console.
Unfortunately, in order to reset the XBox 360 you will need power to be supplied to the console. If replacing the power adaptor or double-checking your connections does return power to the console, you may then reset it by performing a "power cycle" (turning the unit off, then back on roughly 10-15 seconds later).
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 16, 2008 | Video Game Consoles & Games
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Whats wrong?
try plugging in the AV cable correctly
Apr 28, 2008 | Microsoft Xbox 360 Console
My xbox 360 power cord box messed up....
check your Audio/Video cable connection, sometimes those lights means that the plug isn't in the xbox/tv all the way
Jan 06, 2008 | Microsoft Xbox 360 Console
Xbox 360
Make sure all the tv picture and audio cables are plugged in fully, if not fully plugged in, the cables can not work at all. If that doesn't work, consider sending it to microsoft or get new cables.
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
155 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
