Question about Minolta Office Equipment & Supplies
Error C3452 right after power on.
Malfunction C3452 appears right after power on.
  • Minolta Master
  • 6,161 Answers
I assume this is a Bizhub, Fusing unit fault. to clear you will need to look on the right side of the machine, if this machine is networked?, just below the scanner, on the right side is a small cover it will come off close to where your network cable goes. once it is open press the small black button (Looking at the machine from the right side it will be on your left using a paper clip or small screw driver just gently depress the button the machine will go thur its cycle you will get a Trouble reset on the screen with a "OK" touch then power off, wait ten seconds then power on
Posted on Aug 02, 2009
Bizhub 200 erro code c3452
Its related to Fuser Unit,
Try to reset by Switch On Main Power switch by holding Utility Button for 10-15 second.
Troublereset Option will appear
touch it
switch off again and on in normal way.
Dec 29, 2016 | Konica Minolta bizhub 200 Printer
Error C3452
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
if the code comes back replace the fuser, continue to reset can cause fires.and that would ruin a perfectly good day
Jan 29, 2014 | Konica Minolta Bizhub C300 All-In-One...
Error c3452
error c3452 is fusing warm-up failure.
first do trouble reset.
second, check H1 or H2
third, check TH1 and TH2
four, change new fusing unit
five, change PU
six, change PWB-A
Sep 14, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error c3452
Power off the machine wait ten seconds then holding the down the clear/stop button power on the machine. should clear the code if the code comes back replace the fusing unit the hot part!
Jul 23, 2013 | Minolta bizhub 200 All-In-One Printer
How and where to solve /fix error code C-D301 on bixhub c250
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Dec 06, 2011 | Konica Minolta bizhub C250 All-In-One...
Error code c 3452 on ineo 250+
develop ineo 250 machine error comes c3452
how i solve this
Nov 21, 2010 | Konica Minolta Office Equipment & Supplies
Malfunction with error code C3452
HI, If its a hardware malfunctioning then go to nearby service center of contact customer care but before that you can try to reset the device to factory settings or if it's a software isue then you can try reinstalling the drivers from google, its simple.
Jul 29, 2010 | Konica Minolta bizhub C250 All-In-One...
When I turn on the machine (bizhub c300) error code c3452 appears, within 20 secs, How do I reset this code
This is a fuser related code.
To reset the code, please do the following
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch Trouble Reset.
4. Check to make sure that OK is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Good luck
Jan 21, 2010 | Konica Minolta Bizhub C300 All-In-One...
IT KEEPS DISPLAYING ERRO C3452 ONLY. THAT ERROR IS DETECTED BY THE MACHINE I SHOULD PLS CONTACT MY TECHNICIAN.
this is a low fuser temerature code you can reset it by the following method:
1. on the right side of the machine there is a small cover you can remove next to the network card it just clips on pull down on the small lever and pull it down
2. once the cover is removed you will see a connector and a small hole with a switch in it to the right of the connector push the switch with a small object like a ball point pen.
3.when a small dot appears on the touchscreen hit the number 3 on the number pad.
4.enter the 8 digit service code which is 00000000 and touch end.
5. select trouble reset to reset the error code.
if the error code reccurs you will need to replace the fuser unit but i have seen the machines show this error when they are turned on while the room temp is cold first thing in the morning.
Nov 12, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
1,192 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
