Question about HP Pavilion dv6000z Notebook
Hp computor says check cabel
Hp check cable comes up on screen
  • Be_Srg May 11, 2010
    When does this happen?
    Do you have any external devices connected?
  • 53 Answers
If your connected to the modem or router via a cable, check to make sure there are no kinks or bends in it, if there is straighten it out the best you can, if it's tightly coiled up, loosen it up, let it lay down on it's own naturally and work with it that way, sounds like it's got sharp bends and kinks in it....good luck....shia
Posted on May 28, 2009
Gear shift cabel\ bushing
Yes, cables are one piece.
Jul 10, 2016 | Nissan Cars & Trucks
Is there a cable I can use to link my HP laptop up to this tv to watch a movie?
YES THERE IS A SPECIAL CABLE YOU CAN GET THAT WILL WORK . YOU NEED TO GET IT FROM A COMPUTOR SHOP
Jun 20, 2013 | Sony FD Trinitron WEGA KV-32FS16 32" TV
My Computor screen has suddenly Changed to a yellow colour. It is not the screen as it is the same with another screen. It must coming from the computor so please can you advise m,e as to how to change...
That may be due to a cable issue. Please check if moving the VGA cable corrects the problem. It could be that the cable is not fully plugged in on either the monitor or the computer side. If so, you could try screwing it into place.
Another cause of that could be that one of the cable's pins is bent (for example by forcing it in the plug the wrong way). Have a look at the pins of the cable's D-sub and see for any bent ones. You can carefully straighten them out with a small screwdriver and plug it back in.
Hope that helps!
Mar 13, 2011 | Computers & Internet
The screen flick when connected to Samsing Sync
Hello there!
Screen flickering can be caused by instability of cable you are using, or it can be also caused by difference between power input, so check your power plug ,where your monitor and pc are plugged, make sure they are ok for your region, and check those cabels. Also check settings on monitor for what input you are using DVI or VGA or both at the same time.
Sinecerly
Aleksandar Adzic
Apr 16, 2010 | Computers & Internet
My HP Pavilion dv2000 laptop screen fades to white, sometimes comes on white, and I wiggle it to get it on. Sometimes restarting the screen helps.
Sounds like you have a loose connection either on the flat video cable on the left side of the motherboard or the inverter cable on the right side of the motherboard that supplies voltage to the screen. Below is a manual for disassembling the laptop down to where you can inspect and reseat the cables.
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Nov 12, 2009 | Sony VAIO VGN-CR115E/P Laptop
Picture on tv keeps going out and coming on
If the previous posts didn't fix youru problem, and I doubt they did, then you most likely have a weak CRT and the video is being muted. you can sometimes tell if that's the problem by turning up the screen voltage slightly to see if the picture comes back on. If it does, then the CRT is weak. This is a very common issue with Sony CRT TVs, and can sometimes be rejuvenated by a good shop for fairly cheap.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Monitor has power blue light is on. no display. it comes on briefly when turned on then goes off? i am useing a different computor to send this.
possible cause of your problem is: memory, vga card or monitor cable, check all this things if they are in good order.
Oct 14, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
My hp computor screen keeps going white how do i stop it
Check to make sure the cable is connected securely to both the computer and monitor. From the front of the monitor, use the buttons to reset to the factory defaults.
Make sure your video card is firmly in place (if you have added a video card). Also, update your video drivers.
Hope this helps.
Aug 06, 2009 | Compaq Computers & Internet
Computor says to insert windows installation disk but it didnt come with one
If you have a HP Desktop for example, while booting check for on-screen options and select for recovery. Under windows on menu program check for pc tools or related and search for burning the DVD's. This is one time deal, so PROTECT your burned DVD's. On other systems they have similar options.
Jul 01, 2009 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
