Am trying to re-install my Veho 35mm film scanner after a PC "crash" but there is a problerm, the suggestion is I contact you for a solution, perhaps a site where I can obtain an update?, Regards, Rovert Harvey @ robertd.harvey@ntlworld.com
  • Jeff Strader
    Jeff Strader May 11, 2010
    What exactly is the problem?
    President:
  • 1,073 Answers
Hi there Robert!
Go to this site and download the "Download Centre"
http://www.veho-uk.com/support.aspx
That program will check your Veho 35mm film scanner for newer drivers, pathecs and updates.
Good luck Robert
Nic
Posted on May 28, 2009
INSTRUCTION MANUAL
To help you download the user manual for Veho VFS-002M Scanner, please find the link given below:
http://www.veho-uk.com/main/downloads.aspx
GuruAid.com
Apr 26, 2016 | Veho VFS-002M Film Scanner (35 mm)
All pictures have blue tint with T70 35mm SLR
Silly question, is there a filter over the lens? Some folks when using use daylight film in tungsten lighting will use a blue filter. Is the film expired past a few years? If those are all no, then it may be your lab, my suggestion is to contact them. With film there is little to go wrong, you shoot they develop. The magic occurs during developing and printing.
Nov 06, 2013 | Canon T70 35mm SLR Camera
My canon lide 700f will not calibrate to scan a 35mm film
For those having the "Executes calibration. Pull out the film and place the Film Adapter Unit at Frame 1." issue and cannot calibrate the scanner for NEGATIVE FILM, it took me ages to figure out how to solve it.
Solution: calibrate the frame, WITHOUT any film, adapter plug and placed in frame 1, and proceed to do the calibration WITH THE SCANNER COVER OPEN.
Before I tried everyhing, install new drivers for Windows 8.1, MP Navigator, and nothing happen. Now it works like the first day. Hope it helps! it certainly helped me.
Jan 29, 2013 | Canon CanoScan LiDE 700F
I need to use the Veho VFS-002m scanner on Linux. I can't find any way of installing it. Any ideas?
install a program called Cheese. works great but without software dpi interpolation
Jul 30, 2011 | Veho VFS-002M Film Scanner (35 mm)
Negative or positive option is not available on drop down menu on select source on ScanGear CS so how do I scan film? I am trying to scan 35mm film on my Canon 5200 F scanner using ScanGear. The manual...
I just had the same problem, turned out my FAU cable was not properly connected. Ensure that the cable is all the way inserted at the back of your printer, and connect the device to your computer. I hope this will work for you too:)
Jun 24, 2009 | Canon 5200F Flatbed Scanner
Lide 600 film scanner. How does one secure the transparency in the scanner? I can find no slots, grooves, channels in which to slide them.
The scanner comes with a film adapter unit that holds the 35mm film strip. It compensates for the fhinness of the film strip.
You'll have to contact Canon support if you need to purchase one or make a mask using thick paper or a tranparency sheet and attach your film strip with drafting tape (it does not stick aggressively and removes easily.
You might also check with a local scanner repair shop for a used adapter.
Wish the solution was easier.
Apr 27, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
No option to scan Film Negatives
In order to see these options, you must have the Film Adapter Unit (FAU) attached to the scanner. The FAU is designed to scan in 35mm film, either positive or negative. The scanner has no options to scan in mounted 35mm slides.
Does the scanner work for scanning at all? If not, you may have a communication problem between the computer and the scanner, i.e., the computer doesn't know how the scanner is configured so it doesn't show the options. If it's a communication problem, check for any other USB devices that might interfere with communication. Especially, some printers seem to take over communications. Try disconnecting all other USB devices (except keyboard, mouse, etc.), reboot, and see if the situation corrects itself.
Also, try the online troubleshooting database for this model at this link.
Sep 30, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
Twain driver for CanoScan D660U
i have no cd rom to install my canoscan D660U bu ned to install it can u help
Dec 15, 2007 | Canon CanoScan D660U Flatbed Scanner
142 people viewed this question
jasbo
jasbo
