I have a 2000 Buick Lesabre. The radio audio cuts in and out. The radio is always on during this time which makes me believe the problem is between the receiver and speakers. Can you give me some guidance?
  • enko11 May 28, 2009
    Thanks,
    What I failed to mention is on hot days when I get in the car, there is no audio. It seems to happen in hot weather. Is it possible for the problem being in the ribbon that leads from the radio. I have installed a new radio (Alpine with Sirius, IPod) and it happened again.  If you have additional suggestions, please advise.
    ELK
    Novelist:
  • 151 Answers
You are absolutely right .the ribbon is either got misallighned or over streched or faulty.that needs to be checked and replaced.this will solve the issue. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 29, 2009
  • 744 Answers
Hi...
the amplifier is seeing a short problem,or the internal components like one of the output IC's are causing dc to show at the speaker terminals. the speaker protect is causing it to shut down.
Posted on May 28, 2009
Set the clock on a 2000 Buick Lesabre
read you owners manual it tells you there . J. .A. M. i'll call my neighbor and ask him turn radio on the press set on the radio beside the radio there is 2 small buttons one for hour and other for minute .
May 04, 2015 | 2000 Buick LeSabre
2000 buick lesabre quit while running
Could be crankshaft sensor,check fuel filter.
Jun 03, 2013 | Cars & Trucks
2000 Buick lesabre Limited electrical problem This is an intermitent problem which occurs when vehicle is in motion or idling while parked. The warning lights come on the fuel gauge falls to empty the...
From what you have listed , door lock's instrument cluster , radio , HVAC - heating an A/C . An doing it intermittantly an starting to work again after slamming a door or the trunk , I would think a lose ground connection . Most likely in back of the instrument panel somewhere .To be sure , looking at a wiring diagram to see if these thing's share a common ground point . G-200 This would be my first place to look , because everthing that stop's working is grounded here
G200
LH front lower corner of the passenger compartment on the LH front door pillar . You will probably need to remove the plastic kick panel . Do you know what i"m talking about . If not there have the vehicle checked for DTC'S - diagnostic trouble codes , BCM , IPC , HVAC control panel .
Mar 17, 2017 | 2000 Buick LeSabre
My 2000 Buick lesabre cuts off while driving
Your fuel pump might be going bad. The reason why it cuts off is the fuel pump is pumping just enough to run it for a x amount of time that's why it shuts off but while it's off the pump is pumping fuel into the lines. If it's not the fuel pump then it might be your injectors.
Oct 05, 2009 | 2000 Buick LeSabre
I need a new radio, not sure which one.
Go to a scrapyard and buy a radio that comes from the same car you have, with the same steering wheel controls. The only difference will then be that the new one works. make note of any security codes and get vin# from vehicle radio was removed from so that anti-theft feature will not prevent it from working. Radio and wiring harness will not change if you obtain radio from identical vehicle.
Aug 10, 2009 | 2000 Buick LeSabre
WHERE IS THE BATTERY?
I believe the Buick body style is the same for the years 2000 to 2005. The battery for my 2000 Buick LeSabre is under the back seat.
Jul 09, 2009 | 2002 Buick LeSabre
MAF needs to be replaced on 2000 Buick LeSabre Custom
and the question is? it's the first sensor in the duct coming out of the air cleaner
Jun 12, 2009 | 2000 Buick LeSabre
Subs for buick lesabre
yes just purchace an amp that has speaker level line in....then just wire it directly to your back dash speakers,,,,
Mar 29, 2009 | 2000 Buick LeSabre
 Grubhead
Grubhead
