Question about Canon PowerShot S5 IS Digital Camera
Flash won't go off when set to Sports
Flash won't go off when PowerShot S5 IS digital camera is set on Sports.
  • 1 more comment
  • kmeyer1020 May 28, 2009
    The camera has always flashed when on Sports setting. It just stopped doing it. Thanks.
  • kmeyer1020 May 29, 2009
    Yes, it flashes in auto mode and all other settings.
    I'm not sure how to do that.
  • 477 Answers
The camera will not flash in the sport setting unless you have a speed flash attached. because the sport setting is made for taking pictures at a fast pace and the internal flash does not charge fast enough.
Posted on May 28, 2009
  • Mike Johnson
    Mike Johnson May 29, 2009
    does it flash in auto mode?
  • Mike Johnson
    Have you tried resetting the camera in the menu?
My cannon power shot will not register that the flash is flipped up, so the flash will not turn on. How do i fix this
Are you sure you did not select flash off? This setting remains even when you switch off the camera. See basic settings page 14. If on top of the screen next to the ISO symbol is a flash symbol with a bar, you manually switched off your flash.
Oct 26, 2013 | Canon PowerShot S5 IS Digital Camera
Can I use the vivitar 285HV flash for a canon S5 IS?
The 285HV should be safe with modern digital camera. Its trigger voltage is specified as 12V max.
Feb 21, 2012 | Canon PowerShot S5 IS Digital Camera
The camera (Powershot S5 IS) suddenly quit working. It will not power on (tried two sets of fresh batteries). Am I overlooking something very simple? Is it related to the small button battery that...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Aug 11, 2011 | Canon PowerShot S5 IS Digital Camera
Canon s5is no flash
My problem with my CANON S5IS is that flash doesn't fire under any situation ,even when i press to select any available modes by (MIC/Flash)key, nothing is displayed as it's normal functionality, (AUTO,MANUAL,OFF), the key is working because in some other settings it operates normally; there is a problem with Flash command ,can anyone tell what has happen to flash? thank you all.
Aug 16, 2010 | Canon PowerShot S5 IS Digital Camera
At what setting do I put camera to take fast moveing pic.
Use the sports mode, the one that looks like the stick figure running. If you also need the flash set your camera to "Av" and adjusting the Av (meaning aperture value) to the smallest number possible and turning you flash on.
If this still gives too slow of a shutter speed, try increasing the ISO setting.
Mar 14, 2009 | Canon PowerShot SX10 IS Digital Camera
Canon powershot S5 IS flash made popping noise then quit altogeth
Needs repair, You will need to take it to Canon repair center. Google and find the nearest service centre.
It seems like your flash has really pooped!
Feb 26, 2009 | Canon PowerShot S5 IS Digital Camera
Canon S5 IS Flash
Reset your camera to factory settings.
If still you are having the same problem, then you camera will need a professional repair service, since the internal flash board is damaged.
Best regards,
Oct 14, 2008 | Canon PowerShot S5 IS Digital Camera
Can't take photographs when flash is on
Hi
The powershot s5 IS does in fact have some strange behaviour issues especially on the first rev firmware. For example if you take 15-20 flash photos consecutively without powering down your camera the flash recycle times will increase to about 15sec, so you'll have to wait about 15sec before you can take another flash photo. The work around is to power down the camera and then turn it back ON. Another strange behaviour is manifested by its inability to lock focus after taking a "no-flash" photo, then popping up the flash and trying to take a flash photo. Again the work-around is to power down the camera, pop-up the flash and then power it back up. Confirmed these behaviours in two other cameras of the same model.
Jul 13, 2008 | Canon PowerShot S5 IS Digital Camera
Flash speedlite 300
As long as it's an EX flash, it should be fine. Assuming that a T90 is a Canon...I have no idea about that.
Dec 31, 2007 | Canon PowerShot S5 IS Digital Camera
How to power up a Minolta Program 3500 xi flash through a Canon S5 IS?
Im sure that model of Flash. Does the minolta flash fit the hot shoe of the Canon?
If it does then I would first try seting the flash to manual mode and adjusting that.
Let me know if the Flash does not fit and I will try to help you from there.
Take Care,
Caleb
Dec 21, 2007 | Canon PowerShot S5 IS Digital Camera
Canon PowerShot S5 IS Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
