Question about Ovens
Oven will not stay on
Clock/timer flashing and keeps returning to auto when set on manual.dont know how to set time.
  • 6,784 Answers
HI. this is a control fault that can be confirmed by unplugging the unit for 5 minutes. if the control continues to cycle from auto to manual, replace the control board(EOC/Clock)
Posted on May 29, 2009
BO6255SS - The clock turns on but we are unable to set it and therefore cannot turn it on. Can you help?
this is as much as the manual says
After your appliance is connected to your mains supply for the
first time, the numbers on the timer display will flash. Before
you can select a cooking function or set a temperature, you
must set the appliance into manual operation mode.
o To select manual operation mode, press the manual operation
button (9) on the control panel.
http://www.manualslib.com/manual/956107/Baumatic-Bo625ss.html?page=3#manual
Jun 02, 2016 | Baumatic Ovens
Auto keeps flashing on oven display. pressing hand sign wont turn it off.what to do?
Most clocks/timers have 2 buttons. You need to push both buttons at the same time. This should take it off the auto. mode and back into manual mode.
Apr 01, 2011 | Ovens
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
I didnt get a user manual with my creda cooker dont know how to set the timer
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Apr 28, 2010 | Ovens
Cannot set time and Oven will not operate
Depending on the make of oven, you have to press the buttons in a certain sequence if it is a digital one, try pressing the buttons in sequence, sometimes you have to press 2 together, and a third one at the same time,if it is a anologue timer, then make sure you can see the symbol of a hand in the display.
If you cannot get the timer of auto, then it is probably faulty.
Please rate my solution.
Thanks.
Jul 19, 2009 | Ovens
The timer clock has gone off.
to stop the clock area from flashing and for it to display time, the time must be set.
Apr 09, 2009 | Ovens
The top and fan oven keep going off because of the timer. I dont know how to get rid of the timer a I never use it. But I donbt want it to cut out th overn which it is doing. Hel,p and info please
There are 5 buttons next to the clock. From left to right they are:-
Minute Minder, Cook Time, Ready Time, Plus and Minus.
It sounds like the timer needs setting back to manual, so to cancel the automatic setting and return to manual operation, press the Cook Time and Ready Time buttons simultaneously.
To cancel any remaining cooking time left on the clock before the alarm sounds, press the Cook Time and Ready Time buttons simultaneously.
If you are interested, to set the time of day, press the Cook Time button and the Ready Time button simultaneously. Then use the Plus and Minus buttons to set the required time.
To set the Minute Minder, press the Minute Minder button, then use the Plus button to set the required time. You can cancel the minute minder at any time by pressing the Minute Minder button and the Minus button until the display returns to 0.00.
To select an alarm tone, press the Minus button to listen to the first tone. Release the Minus button and press it again to listen to the second tone etc. Releasing the Minus button after the tone has sounded will automatically select that tone.
Hope this helps.
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Oct 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
229 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
