Question about Canon CP1260-D Calculator
Installing Ribbon for Canon CP1260D
The ribbon keeps getting stuck in the mechanisms and I have to cut the ribbon and put in a new one. I must be installing it incorrectly but it seems so obvious how to install. Where can I find instructions? Thank you.
  • 537 Answers
SOURCE: How to insall ribbon
Search Canon's website (www.canonusa.com) for the manual.
I did a quick look but didn't find it there. You might have to call
Canon:
Canon USA offers a full range of customer technical support* options:
  • Toll-free live technical support** Monday - Friday 8:00 a.m. - 8:00 p.m. EST at 1-800-828-4040
  • The location of the ASF nearest you for carry-in service at 1-800-828-4040
  • Toll-free TDD Support Line for the Hearing Impaired Monday - Saturday (excluding holidays) at 1-866-251-3752
  • Technical Support for Customers in Canada at 1-800-OK-CANON
or email link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=9796#SupportDetailAct
Mike
Posted on Nov 08, 2007
old marine
  • 2153 Answers
SOURCE: installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Posted on Apr 17, 2008
  • 136 Answers
SOURCE: installing canon mp145 to computer
You have to download the latest driver from internet and install it.
Posted on Nov 27, 2008
komguy
  • 2306 Answers
SOURCE: We keep getting an error message
Yes, you need a new printhead, QY60061-000
around $40.00
Posted on Jul 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: INSTALLING A CANON D320 TO A MAC
install mac support driver and make a copy
Posted on Sep 07, 2009
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
Why does my Canon MP49D calculator print light?
Could it be you are using old ribbons? Are you using the correct ribbons?
did you put in the ribbon correct and is the ribbon transported, while it is printing, or is it stuck in the calculator. Just some questions to check out.
May 06, 2014 | Canon Office Equipment & Supplies
How to remove ribbon
This comes out of the manual.....
While turning the ribbon take-up spindle release knob counterclockwise, squeeze the
ribbon against the ribbon take-up spindle tension blades.
When the tension blades collapse into the ribbon take-up spindle, hold the release knob
and rotate the spent ribbon toward the rear of the printer. Then, slide the ribbon off the
ribbon take-up spindle.
Now sometimes the ribbon gets wound so darn tight that it might take "Superman Strength Hands" to make this work. In this case I use a razor blade and cut the ribbon off. If you do this please be VERY CAREFUL and, as you get more and more ribbon off keep trying the "NORMAL" method. When you get down to the end make sure you don't cut so hard as to scratch the take up spindle.
Good Luck
mikeo@acebarcode.com
Feb 21, 2011 | Zebra Z4M Printer
Need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
Apr 27, 2010 | Canon MP-25DV Calculator
I have a persona C30 card printer by Fargo and it keeps telling me that the ribbon is broke when in fact it isn't....I put in a new ribbon cartridge thinking maybe I had a bad ribbon, but that doesn't seem...
run forgo diagnostic utility given on your installation cd
Try by doing all the tools under mechanics tab most importantly ribbon sensor calibration and advance & reverse ribbon drive motor by removing the ribbon as instructed by the manufacturer
Jan 06, 2010 | Fargo Persona C30 Thermal Card Printer
New ribbon and can't get it to type
did you make sure that the end pieces are engaged into the brackets in the part facing you. Also if the correction tape is not loaded onto the ribbon prior to installing it, it will do that too.
Hope this helps, Denise
Aug 19, 2009 | IBM Office Equipment & Supplies
Card cutting ribbon on Zebra P330i
On the front of the head. 4 screws are there.
Near the head where the ribbon contacts the card.
Loosen the top 2. Let the metal guard slide down a bit. Tighten the screws. Try a card.
Keep adjusting the guard until you tune it right.
Sketchlab.com
May 13, 2009 | Zebra P330i Thermal Card Printer
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
Canon CP1260-D Calculator Logo
107 people viewed this question
old marine
old marine
