Question about Panasonic NV-DS50EN Mini DV Digital Camcorder
Will not connect to my iMac
I cannot get my camera to connect to my imac, have tried plugging in the firewall while camera is off and while on - same result
Re: will not connect to my iMac
I cant get my camera to connect to the PC, it connects only when it wants!!!
Posted on Feb 22, 2008
0 characters
3 Points
What kind of lead do I need to connect PANASONIC VDR-D250 to IMAC
You need a standard USB to mini USB cable to connect this camera to an IMAC. I do not however know of any drivers available for this combination.
Mar 23, 2011 | Panasonic VDR-D250 DVD Camcorder
Can I transfer my movie info onto my IMac by just connecting the USB plug, then using Image Capture or what?
Greetings - No, the camera has no connector type that can be plugged directly into your Imac (no USB). You would need to buy a separate piece of hardware such as these:
I'm not recommending any particular device but you would need something like it.
Regards, Mikeywaf
Mar 02, 2011 | Canon ES8600 Camcorder
Hi I've connected a firewire cable between the handycam and my new iMac. iMovie/iMac doesn't recognise the connection. Are there settings on the Handycam that need to be made for transfer to the iMac?
No need to change any settings it will auto connected.Check your cable may be its faulty. Try other think to attached your iMC.If still not working then You Firwire driver not instal.
Oct 28, 2010 | Sony Handycam HDR-HC7E DV Digital...
I have a Canon FS100 Digital Video Camcorder. I am attempting to download some video on to my iMac, but then I select "Connect To Camera" I get the message "No Camera Was Found". I have the camera plugged...
The computer is no longer detecting the camcorder for several reasons. It could be the ports on the computer, it could be the cable that you're using to connect the camcorder to the iMac, or it could be the camcorder itself.
Try connecting the camcorder into different USB or FireWire port of the iMac.
Try using different cable.
Try connecting the camcorder into different computer to test the device.
If all else fails, power cycle the camcorder by turning it off and remove the battery for about 10 minutes. Then turn it back on. Otherwise, contact the manufacturer for second opinion.
Hope these helps and have a great day!
Aug 12, 2009 | Canon FS100 Flash Media Camcorder
Problem transferring video from JVC JZ-HD3E-Ek
the stills use the USB and usually video needs firewire, do you have a port marked ieee1394, i-link or firewire?
Mar 29, 2009 | JVC Everio GZ-MC200 Camcorder
My Sony Handycam DCR-TRV480 needs to be put in VCR Mode...
our camera is similar to yours, the switch you switch it on with also goes the other way, this is the vcr mode
Nov 17, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
Transfer JVC GZ-HD7AATOD Files into IMAC IMOVIE 8
download tod converter for mac program, which allows you convert .tod file into imovie understood video, mp4, mov, dv, etc.
Aug 12, 2008 | JVC Everio GZ-MG27 Camcorder
Canon MV 800i and iMac
Please help me to download camcorder mini DV 800i software and drive.
Mar 15, 2008 | Panasonic NV-DS50EN Mini DV Digital...
Transferring video on cassette to Mac OSX
Are you transferring from cassette to memory card and then to Imac? certainly there is software supported by Imac to accomplish this. You can convert your videos to MPEG format using Imagemixer then try uploading with another program. Imac and OSX should have websites that list compatible software.
Dec 09, 2007 | Sony Handycam DCR-TRV25 Mini DV Digital...
Sony Handycam dvd201 and iMac G5
Looks like a rip operation. Close the DVD session and try
Sep 14, 2005 | Sony Handycam DCR-DVD201 DVD Camcorder
Panasonic NV-DS50EN Mini DV Digital Camcorder Logo
44 people viewed this question
Top Panasonic Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
