Question about Frigidaire FSE748GF Dryer
Dryer won't heat up. I don't have a parts manual.
Model # FSE446RHS2 dryer also squeaks when starting up
    Problem Solver:
  • 4 Answers
More than likely the theraml fuse on the back of dryer unplug unit and use a continuity tester to check for ohms. the t-fuse is on the exhaust tube also the squeaks usally comes from the drum rollers use a little silicon grease and lube the roller shaft
Posted on May 28, 2009
How do I identify what part needs to be replaced in my GE Dryer Model DHDVH52 that squeaks the entire time it is drying?
Have a read through this:
http://homeguides.sfgate.com/fix-general-electric-dryer-squeaking-76276.html
There are a lot of videos on youtube about squeaky dryers, but by the article it looks like your belt is going
Mar 22, 2015 | GE Dryers
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
I have a Kenmore dryer model # 96580110 and the heat won't come on when it is operating
Your Heating element may have burned out. Repair clinic has some good repair videos, and a parts department. Sears parts direct is also another source for parts.
Nov 20, 2012 | Whirlpool LEB6200 Electric Dryer
Whirlpool model 110.88752792 dryer runs but does not heat
Concerning the Kenmore 11088752792 model where the dryer spins but does not heat. I had that problem a few years ago with the same model.
I replaced the fuse (part No. 3399849 about $10.00) and the thermostat (part no 3398128 about $25.00). Dryer worked fine the first try.
FYI. Today, I'm searching for what makes the dryer squeak when I came across your issue (though 6 months since you posted, but I figure there are other Kenmore stack-able owners out there searching for a fix). I haven't taken the dryer apart yet but have ordered the dryer belt, rollers, pulley (a package deal with RepairClinic) and the felt bearing/seal. May as well do a full replacement of the likely components that are causing the squeaks and not spend any more time going through trial and error repairs.
If you haven't already, the dogs on your agitator are probably due for replacement as well. RepairClinic has an agitator package deal with replacement dogs and seals.
Jul 14, 2011 | Kenmore 94802 Front Load Stacked Washer /...
First it started squeaking when it was running. Now it squeaks and doesnt heat while running Model #GLER331AS1
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 13, 2011 | Frigidaire GLER341A Electric Dryer
The dryer squeaks - noise is coming from left hand front of dryer. I've take the cover off, there is a plastic piece that if I press toward the front of the dryer stops the squeak. The heavier the...
The squeak is actually the rear bearing WE3X75.
98fbf6b.jpegOddly enough although this might be your part you should use your model number to order the part. Different production runs I guess. Theis dude mounts in the rear
66ec823.jpgright in the center of the heater. This bearing gets real thin and when almost gone starts the squeal. You must remove the drum to get to the backside and replace that dude. I have a pictorial and more HERE.
Oct 12, 2010 | GE DBXR463GB Gas Dryer
Dryer will not heat up. can not get the top of dryer off to look at the wire diagram to be able to check fuses. MOdel FSE446RHS2 Frigidare.
I have the wiring diagram directly from Frigidaire. All you need is adobe acrobat reader to use it. It has a parts breakdown as well as the wiring diagram. However I can tell you that there are 3 inside this dryer one at the top back left portion of the dryer. the thermal limiter. One on the heater housing. And one on the blower housing.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/5995381570.pdf
Nov 07, 2009 | Washing Machines
I can't find the thermal fuse on a fse446rhs2 electric model
Location is inside the cabinet on the back wall. Upper right hand corner by where the terminal block is. Mounts by 2 screws. Part number 134120900 .
Sep 15, 2009 | Frigidaire FEQ1442ES Electric Dryer
Squeaks FSE446RHS2 XD41513722
You can generally access the unit from the rear panel. Try and lube the joints around the pully for the belt and any other moving parts. Hopefully you won't have to replace any parts. Good luck
Apr 10, 2009 | Frigidaire FSE748GF Dryer
Frigidaire stackable dryer fse446rhs2 makes a bumping noise
heatman101
dfghjhd
Nov 08, 2008 | Frigidaire GLGQ2152ES Gas Dryer
Dryers Logo
149 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
