Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Pictures very dark, Brightness all the way up. Contrast does not adjust
My Hitachi 46f500 rear projection HD TV became very dark and hard to read menus 2 days ago. I have the Brightness turned up all the way. The contrast does not seem to change when I adjust it. Some pictures are so dark I can not see. The menus and banners can be hard to read sometimes. Thanks
I have the same problem. I was able to temorarily fix the issue by taking the back cover off and blowing all of the dust out. But this only worked for two days. Now the problem is back. Did you fix the issue with your tv? Thanks.
Posted on Feb 10, 2010
I have an Hitachi 53sdx01B rear projection HD TV. Worked great until yesterday when it seemed like the contrast or brightness got out of whack. Whites appear to be overly bright, to the point that...
The tv have picture look like a bright dull hallow glow to the screen,yes,than the tv CRT tubes coolant chemicals is bad.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to do the replacement.
Feb 05, 2011 | Hitachi 53SDX01B 53" Rear Projection...
I have a Hitachi 46F500 tv and the red crt bowed
I just had the convergence replaced and have a great picture
Aug 16, 2009 | Hitachi 46F500 46" Rear Projection...
Hey own a 2003 hitachi model #46f500. love it a lot,but has a tint of red on screen. when dark movies are on gets real dark. when its day light on tv it looks great. info please
It sounds like the CRT tubes are weak which will not practical to replace them.
But try to clean the dust on tube first and if it doesn;t help do this...
Caution!
Risk of electric shock, focus block carries 4 kilo votls, do at your own risk or DO NOT do it at all.
Just try to adjust the screen voltage adjustment to brighten the 3 tubes from focus block, to do this you have to open the back then let the TV run for abut 10 minutes beofre adjusting, each tube has its own screen voltage adjustment, read the label make sure not to tuch the focus adjusment, do not crank up too much make it very slow or your TV will show retrace lines or it will shutdown.
good luck.
Feb 27, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500 will not recognize a Playstation 3
It is my understanding that the 46F500 HD Ready only goes to 1080i and for Blu Ray you need 1080p. There are no ports for this format.
Nov 17, 2008 | Hitachi 46F500 46" Rear Projection...
46" Rear Projection Hitachi - Green / Yellowish Screen
daveT29 - I had my brightness cranked, too. The picture went dark and off-color after moving the TV from one corner of the living room to another.
After waiting for the TV repairman for about 4 weeks, I "fixed" it myself. Take the front panel off (4 screws, then a black panel) and blow out all the dust. I was afraid to use a swiffer duster because of the static electricity, so i just used with my mouth blowing powers.
That's it. Seriously.
Jan 09, 2008 | Hitachi 46F500 46" Rear Projection...
Picture is dark
Pull the back off and tap on the deflection board. Does it get brighter? If so, you have a bad connection and or cold solder joint.
Dec 07, 2007 | Hitachi 46F500 46" Rear Projection...
Picture adjustment
usually there is options in the menu button on the remote to fix the brightness contrast etc also make sure your hdtv cables (make sure you have these if not you will not have good picture)are working and connected properly.
Nov 23, 2007 | Hitachi 46F500 46" Rear Projection...
Adjusting visuals on the TV does nothing
This problem may have been coming from the Flyback Transfromer or the Tippler, you have to be a technician to adjust that! if you are, well first thing is to put the TV ON and sent up all the level to max for the brightness & Contrast, then after try to adjust the Flyback screen voltage for hi bright, if it work there, try back now to see if you are getting any control of the menu of brightness & contrast to work! please be careful, there about 28K volts to 35K volts, this can kill anyone... IF YOU ARE NOT A TECHNICIAN PLEASE DO NOT OPEN THIS TV.... RandyXi CriticaL PaniX
Jun 29, 2007 | Sharp 55R-WP4H 55" Rear Projection...
Bad picture
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 26, 2006 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
254 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
