I have a problem with my 1994 Daihatsu Applause automatic i have changed my front brake pads and since then my handbrake light on my dash will not turn off when handbrake is released i'm not sure what has happened?
Check your brake fluid level i had same problem on a different car with handbrake light staying on and when i checked brake fluid it was on minimum light went back to normal after topping up fluid in the reservoir check the fluid "DOT" rating before buying this should be on the cap (ie DOT 4 fluid only)
hi brake fluid is topped up to max..
