Question about Toshiba Satellite M45-S2692 Notebook
Display flickers and has horizontal lines
One day three horizontal lines appeared on the display and the bottom tool bar sunk to the bottom of the screen (meaning I could no longer see the toolbar but I could click on the start button etc. if I moved my cursor below the last visible part of the bottom of the screen.)
However, once I tilted the screen forward a little bit, the problem went away. It gradualy started doing this more often and eventually I couldn't fix it by moving the screen anymore.
I removed the cover from around the screen and touched the inverter chip and the problem went away for a day or two and then started again. I replaced the wiring harness that goes from the screen to the plug next to the left speaker but that didn't help. I'm gonna try putting a new inverter in next I guess.
Has anyone had a problem like this before? I don't want to buy a new lap top because I'm pretty sure this problem is fixable!
  • nickivanovic May 29, 2009
    Thanks, but I already replaced that cable and didn't have any luck.
  • 39 Answers
When you had the screen out, did you check that the wider flat cable going up in the middle of the screen was tightned and connected properly?
if that doesnt help i would try to change that cable
Posted on May 28, 2009
I have a Toshiba Satellite M45 and the monitor no longer works. there are some lines on the screen (left) and the rest of the screen is black.
Can you tell us please, what - recently - happen to the lap? have it been shocked, dropped down ,,, ?
To test, u can plug external monitor in the VGA-port, turn ON the laptop, after a minute, toggle the display once, or twice, or 3 times to change the display path to the external monitor.
Tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite M45-S2652 Notebook
Screen display has gotten smaller.
Well this is unusual & interesting.. (sic)I can still see the entire window(sic) I wonder if somehow the Display Drivers have gotten Screwed up.. Try un-installing your graphics hardware Drivers,then re-install the latest Drivers for your system. Of course B4 ya do any of that try adjusting your windows display to any other resolution and see if this changes things.. Below is a helpful link... www.microsoft.com/enable/training/windowsxp/appearance.aspx
Aug 21, 2007 | Toshiba Satellite M45-S351 Notebook
I continue to get a message from MSN about a tool bar problem. I have had a report sent to MSN many times, but the message keeps appearing. How can I get rid of it?
uninstal the MSN Messanger and reinstal and be carefull when you instal to uncheck the box that tell you to instal a toolbar,and it will not apear.
Nov 24, 2009 | Toshiba Satellite M45-S265: M45-S265...
Toshiba M45, no display, no boot, display button lights up about 3 seconds.
I have same problem with L30/L35 mainboard
did u find solution for your problem?
/o\
May 18, 2009 | Toshiba Satellite M45-S2692 Notebook
No display on screen, but i have sound
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 21, 2009 | Toshiba Satellite M45-S269 (PSM42U016006)...
Toshiba Satellite M45-S169
Try booting into safe mode
Press F5 on the keyboard every few seconds when your start the computer.
Go into the Device Manager and remove the Display Adapter ( Video Card)
Restart the computer normally.
Let me know what happens.
Mar 03, 2009 | Toshiba Satellite M45-S169 Notebook
Booting problems with my Toshiba Satellite P105
Try to reinstall the video driver from Safe mode.
It appears your hard disk is OK but the operating system and or registry is corrupted.
1. Try installing the video driver first.
2. If it still does not work, back up your data files in Safe Mode then re-install XP again, make sure you delete the partition and create a new partition and do a full NTFS format, not a quick format.
Nov 12, 2008 | Toshiba Satellite A25-S207 Notebook
Image result over bright at day light
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=10630
May 23, 2008 | Canon PowerShot A400 Digital Camera
My Screen!!!
hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
Mar 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Open Questions:
BSOD when trying to install Win XP, or boot Win XP from hard drive BSOD screen is as follows: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: The BIOS in this system is not fully ACPI compliant. Please contact your system vendor or visit http://www.hardware-update.com for an updated BIOS. If you are unable to obtain an updated BIOS or the latest BIOS supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable the ACPI and allow you to continue your installation. Technical information: *** STOP: 0x000000A5 (0x00000011, 0x00000006, 0x00000000, 0x00000000) Every BSOD I received was this exact code. I ran a RAM test with memtest86+, it showed 0 errors. I tried reinstalling BIOS v 1.1 (supplied by Toshiba) and the first time it did let me boot into the XP Home installed on the system, after which it worked fine. While in xp, I checked device manager to see if the system was ACPI, and it was. I've also tried BIOS v 1.2, the last one supplied by Toshiba, to no avail. I did try pressing F7 during one of the installation attempts, and it hung at "setup is starting windows", I tried pressing F5 during an attempt, and there was only one option besides "other", the typical i486, which I selected, after which it hung at "setup is starting windows". I've flashed BIOS with v 1.2 a few times now, with same BSOD during both xp install attempts and boot attempts. What baffles me is the errors did not show up until I tried to install xp for the first time. Before that the computer booted every time. I've never heard of xp effecting BIOS during install. I have been to the microsoft support page for this BSOD. There are two articles on this specific code that I found, one for a "wake from hibernation" error, and the other for an xp installation error, seems as though the latter applies here. URL below. http://support.microsoft.com/kb/314830 I'm fixing this for a friend. I fix computers all the time. This one is getting up there with DELL's laptops. The screen is broken, so I'm using an external monitor. He doesn't want the monitor fixed, so I'm only doing a fresh install + Backup for him. Thank god I already backed up the data. Thank you in advance for your time. (I just got the error again. Gonna try windows 7.)
Jan 21, 2013 | Toshiba Satellite M45-S2692 Notebook
Toshiba Satellite M45-S2692 Notebook Logo
197 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
