Some cameras cannot take certain types of SD cards. They could be too new for the camera or have a higher storage capacity than the camera can recognize. Sometimes you can update camera firmware to accept these cards, but often you are limited to what the camera can accept.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
In DSCT1 Camera, the E:61:10 error message indicates a Self diagnostic message. This message can be clearly identified by the help of a Sony Authorized service technician. Each of these codes indicates the symptoms and resolutions of the Camera. The E error code indicates the internal hardware malfunction with the Camera. This issue is not related to the CCD Image Sensor replacement. Try the steps given below to check if the issue can be resolved.
·Turn off the camera.
?·Remove the battery pack.
?·Press and hold the power button for 30 seconds.
?·Allow the camera to remain without power for 60 seconds.
?·Reinsert the battery pack.
?·Turn on the camera.
Also, try resetting the Camera back to factory default by pressing the RESET button using a sharp-pointed object. The RESET button is located at the lower right side of the control buttons.
Please make sure that the Camera is turned ON before you reset it.
That's the bug in Nokin L100, update the firmware version from 1.0 to 1.1, this will solve the battery exhaust problem. Firmware version 1.0 has only 2 battery (Alkaline and Lethium) option where as Firmware version 1.1 has Nickle battery also. But, to update the firmware you need to have EH-67 AC Adapter to give power to the camera.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Camera needs to be serviced. This is a common problem with sony cameras. If you have any knowledge of electronic, you could take apart and clean and lube lens. If not sony will fix for a fee, go to the sony web site, they offer a repair service. This happened to mine, it cost $95 plus shipping costs to repair. Now it works great, for how long who knows.
error messages are for camera repair technicians and are found in repair manuals. have your camera checked by a camera repair shop tech.i would get an estimate first.
I have a similar problem. The contacts seem temperamental for the XSI on this lens. But strangely, I've found as long as you aren't focusing in on a bright image, it works just fine. The only thing I can figure is with a 300mm magnification is that it doesn't want to burn out the chip so it's a built-in protection of some sorts. Try cleaning both the contacts on the lens and the camera body gently. Does the problem happen as soon as you turn on the camera, or mid shot?
when using the camara getting a sensor error camara
when i go to start the camera it comes up with sensor power error
Sensor power error when i try to use camera...
