Question about Marantz SR6001
Marantz sr6001 amplifier is flashing on standby continuously
Arrived home and turned tv, marantz amp and foxtel on to watch a good night's viewing. There was a loud noise then everything switched off. I checked all the plugs, wall switch okay, power board with trip switch does not seem to be working anymore. Changed power adaptors and turned everything on again and everything seemed to be working fine, tv, amp, speakers, foxtel. A few minutes later the amp switched off and went to standby. It keeps flashing on standby and there no display on the amp window. Couple of times turned amp off and few minutes later turned it on again, then turned the input selector dial, there is a short display on the amp window then everything goes blank and just keeps flashing standby again. What is wrong and what can I do to fix this problem?
  • ngerutoa May 28, 2009
    Okay, what does it mean to me if I have a blown amp. Is my amp dead, is it fixable and if repairable - is that expensive and worth looking at buying a new amp? Your comments would be appreciated.
    I suppose not the reply most people would hope for but probs the one I was dreading, as do all others. Need more advice so have posted a reply. Would appreciate response to second question. Also, thank you for a speedy reply.
  • 355 Answers
This unit went into protect either due to overcurrent or dc detect. There is no way to disable protection that Marantz or Authorized servicers are allowed to give out. The early versions of this model all you had to do was unplug for a few minutes then plug back in and unit if it did not have blown amp unit would powerup and work fine. But if amp had failure it may cause more parts to fail so they changed software to not allow users ability to disable protection. Send to Marantz Authorized servicer for them to check for amp failure or mayby they just have to disable Protect Mode.
Posted on May 28, 2009
MARANTZ TV _ XBOX connectivity:I have a Marantz PD5040D TV with plasma monitor. A Foxtel blackbox is connected to it so that I can view about 20 Channels. This works well. I now want to connect an Old Xbox...
Yellow= video lead - connect to either terminals C (have you tried all 3?)
Red/White = audio leads - connect to D
Make sure source<on remote> is set to correct video terminal <1,2 or3>
If that doesnt work perhaps try the yellow cord going to either of terminals F untill you get a picture... but it should work!?
May 07, 2017 | Televison & Video
Marantz sr6001 stanby blinking
It is possible that the amplifier had encountered a fault with a higher current drain which had triggered it to a protection fault condition. The fault can be with your output drivers. Please check for short on the outputs fitted for both the channels. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise which can be a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board. Maybe the protect circuit by itself is shutting off due to a faulty bias or there is a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the amplifier comes out of the protect mode then check for short on the speakers.
Dec 09, 2011 | Marantz SR6001
What is the setting for the Marantz SR6001 channel 2
It's not clear what you're requesting but I'm sure it's in the manual...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR6001-Receivers-manual/id/2536ag202/t/2/
Apr 09, 2011 | Marantz SR6001
Marantz sr6001 amplifier flashing on standby continuously
hi there
check settings for this configuration ......if you have a subwoofer in the settings, for best overall results choose subwoofer yes, and set main/center/surrround to small....if no subwoofer set left/right speakers to large and small to center, if there is no loe frequency effect (lfe) going to the subwoofer it will go into standby....hope this hlps ....shia
May 28, 2009 | Marantz SR6001
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
Jan 21, 2009 | Marantz SR6001
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Try pressing the power, and multi speaker button at the same time. But first turn the unit off...then press the above buttons at the same time...This is for the SR6001... GH
Feb 16, 2008 | Denon DRA-395 Receiver
Reciever not working
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
Feb 16, 2008 | Sony STR-DE345 Receiver
Marantz SR6001 Logo
549 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
