Question about Kenmore Sewing Machines
Clutch won't release.
Our old Model Kenmore Model 1217 sewing machine's clutch won't release.
  • 980 Answers
This what you do, get a wide blade screwdriver, place the screwdriver blade on one of the slots or grooves on the stop motion wheel on the left hand side as you look at the machine from the end, the the top of the handle a good thump and you will find it will release, don't over tighten once you have freed it off.
Posted on May 29, 2009
My Kenmore Sewing Machine Model #1217 Wont wind Bobbin
These are durable machines. Suggest removing the top and inspect the bobbin winder. The winder tire may have failed and need to be replaced.
If the tire is intact confirm that the shaft is free to turn and does not require lubrication.
Two screws secure the top and will require removing to access the winder.
It is douhtful that the hardware has failed.
Hope this helps?
Dec 21, 2016 | Kenmore Sewing Machines
Bobbin rewinder won't work
it's possible that there is a part inside the machine that could be broken, it would be a good idea to have the machine checked.
Jun 23, 2013 | Kenmore Sewing Machines
the machine needs to be serviced by a sewing machine repair shop
Jan 25, 2012 | Kenmore Sewing Machines
How do I find the model # of a machine I purchased? There is nothing written on it except a serial # G14111573
I'm looking at your question now
& it's showing me a Brother sewing machine--model number LS-1217
is this correct?
Oct 21, 2010 | Brother LS-1217 Mechanical Sewing Machine
On my Kenmore 15250 sewing machine to wind the bobbin I need to release the clutch by turning clutch knob towards me, so says the instructions booklet. But the clutch knob does not move apart from the...
On my Kenmore I had to pull the knob out to release the clutch, then push it bak in. I don't know if that is the same for you. You can try it, if it doesn;t move, it was worth a try. You could just take to Sears, sewing machine department and ask the salesperson what to do, they should help you for free, our Sears is pretty good about such matters.
Sep 13, 2010 | Kenmore 15208 Mechanical Sewing Machine
Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Jan 20, 2010 | Sewing Machines
Can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Feb 14, 2009 | Kenmore 15516 Mechanical Sewing Machine
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
304 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
