Question about Gateway MX8734 Notebook
Gateway MX8734 crashed and will turn on for 1 second then die
I never had any problems with the battery at all and yesterday the computer just shut off out of nowhere. Now when I try to turn it on...
--the blue on/off button lights up for one second
--the red plug looking light below the keyboard lights up
--then it turns off again
--meanwhile, the battery indicator on the front of the laptop is solid blue which usually means the battery is charged.
I've tried to take out the battery, connect the cord, and then turn it on and I get the same result. Is this a faulty motherboard or does this sound more like a batter/charger problem etc.
Thanks for any and all help.
  • 3 Answers
Try a new battery. It might be a bad brand of battery.
Posted on May 28, 2009
What is the maximum memory on a Gateway MX8734 laptop?
Hi Anon
the Gateway MX8734 motherboard has two memory slots each capable of handling a maximum of 2gb of ram.
So, 2gb is the largest single ram module, and 4gb is the largest total amount of ram.
If you are uncertain if your motherboard is capable of handling a 4gb ram upgrade then check with the memory suppliers first.
In practice I have always found that the performance difference between 2gb and 4gb of ram is slight.
Aug 14, 2014 | Gateway Computers & Internet
My Gateway laptop, NE56R1u, shuts down automatically when unplugged even though fully charged?
Dear Leslie,
I had the very same problem with a HP Pavillion DV4 laptop and the problem was inside the battery - one of its cells became defective and the charge did not last more than a few seconds - it also showed a 100% charged icon but the battery was depleted in seconds.
Before buying a brand new battery you could check with a friend that has a similar laptop if he/she can lend you his/her battery for a few minutes and check whether the laptop keeps on or not with that other battery. In the case it remains on, it is the battery for sure, and you will need to buy a replacement one. Check the link below, for one option.
Hope you may find this information useful!
Best regards,
Miguel L. Martins
6cell Laptop Battery for Gateway NE56R41u NE56R42u NE56R43u Nv50A02U...
Feb 19, 2014 | Gateway Ne56r31u Intel Celeron B830 X2...
What is the max ram I can install on my Gateway MX8734
This model Gateway can support 4Gb of RAM.
The RAM you installed may not be compatible with each other.
Use RAM of the same make and speed.
Dec 31, 2012 | Gateway MX8734 Notebook
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
My gateway profile 4 desktop will not power on. nothing happens when I push the power button. measured 12v at the computer end of power cord. switch look ok. worked fine yesterday.
Remove the power cord and then take out the battery. Hold down the power button for 30 seconds, then plug in just the AC powercord and try turn the laptop on.
If it turns on let it boot into the operating system and then shut it down and put the battery back in.
Hopefully this will resolve the problem but if it doesn't turn on again with the battery in there is a problem with the battery.
Post back if you need more advice.
Good luck.
Jun 27, 2010 | Gateway Profile 4 All In One (MPN...
My computer keep crashing
Try to turn off the pc, then remove the cables and the battery. Then press
and hold the power button for 5 seconds. Then reinsert the cable and battery on the
laptop. Turn on the pc and check if it keeps crashing...
May 10, 2010 | Gateway ML6230 Notebook
I have the same problem with mine no power
I have an MX8734 and it died on me. I have 3 batteries and 2 power adapters but there is a bigger problem at work here!
These computers (almost all gateways) have a big power supply plug (connected to motherboard) defect. They are a $6 part but the moboards are $400!
You can send it to a computer repair shop but beware,,, as some don't know how to fix plug and will tell you its the motherboard. Because its a defect it can happen again after repair. Gateway doesn not repair units anymore as acer bought them and a 3rd party is doing warranties (or not doing them from what I hear).
If I was you I would: A) Have a shop that can fix plug do it.
B) Put it on Ebay for parts (worth about $200),
C) Have a real expensive (but satisfying) target at the ol range.
Aug 04, 2009 | Gateway MX8734 Notebook
My CD tray is not reading cd's or dvd's. can it be fixed?
i had a gateway and that happened. i had a bestbuy warenty. wat they did was replace the drive. if u buy a new one i suggest a hp or compaq cause when best buy replaced my gateway the hp seams to be reliable. dont buy from bestbuy
Jun 23, 2009 | Gateway MX8734 Notebook
Gateway laptop MX8734 Notebook will not power up
If it is plugged into the power cord, it will boot up. Radio Shack and Batteries Plus has good deals on batteries and carries most brands.
Mar 18, 2009 | Gateway MX8734 Notebook
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
Gateway MX8734 Notebook Logo
386 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
