Question about Singer 6038 Mechanical Sewing Machine
Bobbin threading I have just got a singer 6038 and I need to know how to thread it...It did not come with a manual I need to order one, but I would like to use it asap. Could any one walk me through it? Thanks, Heather
5 Suggested Answers
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
Posted on Aug 16, 2009
SOURCE: threading bobbin for singer 8734
Posted on Feb 14, 2010
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 139 Answers
SOURCE: how to thread the singer 6038 at the needle part
You can find Singer threading diagrams at
Posted on Apr 16, 2010
I have just purchased a second hand Singer 6038. When sewing, the machine hesitates about every 15cm of sewing causing the stitch to go off centre. The tension is fine whilst trying various stitches.
I'm wondering if there is a possibility that a puff ball is getting in the tension, needle or bobbin. You might want to look at your thread in the light to see if it is fuzzy. Replace it with good, embroidery thread from someplace other than Walmart. Anyway, do a good cleanup in those areas to ensure there isn't buildup of thread.
Nov 28, 2016 | Singer 6038 Mechanical Sewing Machine
Why won't thread stay in the needle?
Is the thread pulling out of the needle when you first begin to sew? If so, be sure you are pulling sufficient thread through the needle at the outset--between 4-6 inches. You can also try bringing the bobbin thread to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Aug 18, 2015 | Singer 6038 Mechanical Sewing Machine
Singer 6038 tension dial not working
there should be small washers ( discs with a tapered flange to direct the thread between the plates ) if they are not under the spring behind the tension adjuster knob then that will be your problem
if they are there then check that the tread is between the plates and not behind them
missing plates are available from a sewing machine mechanic sgop
May 07, 2017 | Singer 6038 Mechanical Sewing Machine
Hello. I am working with a Singer 6083C. When I turn the wheel, the thing in the bobbin goes around but the thread doesn't catch. I'm wondering if this is because I've put the bobbin in...
Have you recently changed the needle? If so, please check if it is in the right way, flat shank to the back. This is easy to get wrong and will prevent stitch formation as the scarf at the back of the needle (scooped out area) is where the rotary hook goes to catch the thread during stitching.
Jul 13, 2011 | Singer 6038 Mechanical Sewing Machine
Do I need to remove both metal plates from the bottom in order to thread the bobbin???
No, you should only have to turn the hand wheel towards you and you will see that the thread will hook on the bobbin thread if you have your cover off.
Apr 17, 2011 | Singer 6038 Mechanical Sewing Machine
How do i put the bobbin case back in correctly?
The zigzag setting should not have caused it to jam up unless the tensions were off and the thread was bunching up on the bottomside of the needle plate. If you ever jam or break a needle be sure to replace it with a fresh new needle. A slightly bent needle will cause all kinds of problems.
When putting the bobbin back in make sure you keep a good amount of thread hanging out and manually turn the hand wheel around until the needle make a full rotation. The hook should catch the needle thread and allow you to pull the bobbin thread out through the needle plate.
If you jammed it really good it is possible that the needle and hook timing is out of sync in which case you may need to have it re-timed.
Jun 08, 2009 | Singer 6038 Mechanical Sewing Machine
The fabric gets pulled down into bobbin compartment and thread gets all bunched up hard to remove
It sounds like your bobbin compartment might be pulled out of alignment. You might want to take the bottom plate off, clean off any lint and threads, and put the bottom compartment back in. Follow your manual if you have it. With your right wheel, slowly start to sew is the top or bottom thread having problems? You may have to rethread top and bottom. I found that one time, my top thread was not threaded correctly.
Mar 24, 2009 | Singer 6038 Mechanical Sewing Machine
Thread on bottom, bobbin thread loose
Sounds as though you've misthreaded the upper tension. The best way to verify this would be to thread your machine, lower the presser foot on to the material. Now try pulling the thread through the needle. (Assuming your upper tension dial is set to a number greater than one). You should feel resistance. Should you not feel resistance, rethread your upper tension.
Feb 01, 2008 | Singer 6038 Mechanical Sewing Machine
I can't find my manual and cn not get the bobbin to thread correctly
you need to insert the bobbin so that when the thread pulls off it spins counter clockwise. on the side closest to you there is a notch that you slip the thread into and then pull along the side towards the back of the machine staying on the left. once you've done that you can manually turn the knob on the side to make the needle cycle down so that the upper thread will pull up the bobbin thread.
Nov 25, 2007 | Singer 6038 Mechanical Sewing Machine
Singer 6038 Mechanical Sewing Machine Logo
37 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
