Question about Polaroid FLM-3732 Television
Power to the tv just stopd and it is not the cored the red light to sho the power is on is not on
My tv was working fine then the power to the tv just stopd I thout it was th power cored But thats not the problem the red light to the tv ust to be on but now nothing Simply will not turn on. Get the blue light, but nothing happens. Will not turn on either manually or thru remote. Set is only 3 yrs old.
    President:
  • 814 Answers
This unit has had a component failure.The unit should be sent or taken in to a service center for testing and service. The Polaroid customer support telephone numbers are 1-866-925-7278 and 1-866-289-5168. Give them the model number of you television and the problem you are having with it. They will be able to help you with your problem.The Polaroid customer support website is: http://www.polaroid.com/CES/support.jsp Give them the same information and they also should be able to direct you to a service center, that will help you with your problem. I hope this information help you with your problem.
Posted on May 28, 2009
My Samsung TV doesn't show a picture, when there was a picture audio and remote not working. Which boards need replaced?
If there is no audio then most likely your main board. If your red power stand by light blinks less than 3 s then its the M/B. If its more than 3 s then its the P/B.
Sep 03, 2015 | Samsung PN50C550 50 in. TV
Tv was working fine. turned it on, the green power light flashes. power it down and the power light is steady red and the lamp light flashed red
you need to replace the lamp This unit has 2 different LAMPS used, one is SQUARE and the other is ROUND.
Dec 18, 2010 | Zenith Z52SZ80 TV
What does the red light mean next to the power button?
The red light next to the power button is usuall the hard drive led which should blink every time the hard drive is in use, there is normally a green or yellow light for the power that shoukld stay on constant when the computer is on.
Feb 09, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Hi i got an xbox 360 with 3 red lights &
yea...ur gonna have 2 send that in 2 microsof...heres the # 2 call them 1-800-469-9269
Oct 28, 2009 | Microsoft Xbox 360 Console
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
My lg rear projection tv stopd working at onece and there is no light in the indicators .its model no is mw-60sz12. can it happn becouse of lamp
1. Unplug the cord & check if there is power at the
outlet.
2. Check for a busted fuse/or tripped off circuit
breaker at the main power panel pf your house.
3. Check for the busted fuse inside the case of your
projection TV. This is just near where your power
cable of your TV is connected.
4. When you are done, plug back your cord to the
power outlet, and put the power on.
This should correct your problem. Send us your email and keep us informed.
Sep 27, 2009 | Televison & Video
The following link posted by stiv0 gives detailed instructions on how to replace the two capacitors that commonly go bad on this TV. When these capacitors go bad they prevent the TV from turning on. However, you still get a red light when you plug it in. Since your not getting a red light I'm not sure this fix will work for you. I'd open up the TV and see if the capacitors are bulged out as described in stiv0 post. If they are I'd go ahead and replace them and give the TV another try. This fix is fairly easy to do and very inexpensive so you don’t have much to lose.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
May 20, 2009 | Polaroid FLM-3732 Television
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
X2gen 19 inch wont turn on.
my Acer Orbicam that takes picters and vidios stopd working just like that and i dident do enithing rong it just stopd working please can someone help me
May 30, 2008 | X2Gen MG19MY 19" LCD Monitor
Televison & Video Logo
255 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
