Question about Zebra 2746e Thermal Printer
Zebra 2746e will skip leaving a blank label while printing.
It will print off labels then it will skip leaving a blank label then start printing again. I get 5 good labels then 1 blank label.
    Scholar:
  • 31 Answers
You need to calibrate. Hold down the feed key while powering the printer on, then let go. The printer will calibrate, print a config label, then fo into dump mode. Press the fee key again to go out of dump. Of your issue persists, there could be a problem with yoru media, or with the commands that you are sending to the printer.
Posted on Jan 31, 2010
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
TLP 2742 is printing blank labels
Skipping labels is normally a calibration issue or label template size. Solution: TLP 2742 is printing blank labels
Apr 02, 2012 | Zebra Eltron TLP 2742 Thermal Label...
Hi there, I am printing on Zebra S600 using Seagull Scientific Driver, The printer only prints every alternate label that is prints one label and prints a blank. Thank you for your help
Skipping labels is usually a printer driver issue. You should use Seagull Scientific printer driver only if you are using the corresponding Seagull Scientific label design software. It is important to have the printer driver and label design software be from the same manufacturer.
Jul 01, 2011 | Zebra Stripe S600 Thermal Label Printer
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
Label header or footer is out of page
chech if the tipe of label is correct from the driver (length and with)
Apr 27, 2010 | Zebra 2746e Thermal Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
New z4m is printing the data too big for the label and is skipping labels. Prints one, then a blank. I have several Zebra printers and the set up seems to be simular however I cannot get this one to print...
have you installed all the drivers correctly
and are you printing using the software that came with the printer or are you using word
if you are using word change the diamentions of the sheet when you go to print
Dec 29, 2009 | Zebra Z4Mplus Label Printer
Zebra label alignment
you can adjust this in the template file for your price tags. how did you create your basic price tag label? in the zebra label creator? if so, make the adjustment there. if you have a .ejf file for your price tag label, you should be able to open it in notepad and add the height in pixel dots with the "q" or "Q" command from the EPL programming handbook. This can be a little tricky, but with some trial and error, you can get it.
EPL2 programming guide:
http://www.zebra.com/id/zebra/na/en/documentlibrary/manuals/en/epl2_manual__en_.DownloadFile.File.tmp/14245L-001rA_EPL_PG.pdf?dvar1=Manual&dvar2=EPL2%20Programmers%20Manual%20(en)&dvar3=2746e
Mar 23, 2009 | Zebra 2746e Thermal Printer
An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Mar 16, 2009 | Zebra 2746e Thermal Printer
TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Dec 08, 2008 | Zebra LP 2844 Thermal Printer
Zebra 2746e Thermal Printer Logo
2,040 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
