Question about Janome Memory Craft 5700
Mc 5700 problem
Bobbin thread shows through badly when embroidering using memory card
  • Janome Master
  • 1,388 Answers
Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
http://www.fixya.com/marketplace/servicepage.aspx?srvid=17197&ctgid=164&brdid=0&prdid=0&smid=23884&mthid=1&mpsaugid=541e3da8-c9d3-4504-9da5-f8ed5ebb8fcf
Posted on Nov 28, 2011
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
You don't have much info here to go on. I take it that it embroiders fine otherwise, ie on the built in designs. Is it a Janome card? Does it do it on a particular card / design? Have you changed the bobbin thread that you use? Check the top tension - even though it is 'automatic', it does require adjustment at times. Have you changed / using stabiliser that you use? Is the bobbin correctly threaded?
Check these things
Posted on Oct 22, 2007
Bobbin thread shows on embroidery pattern
The bobbin thread is being pulled too hard by the top thread. The idea is to get an even pull similar to a tug of war. When it is even the thread will form a knot in the middle of the fabric.
To fix this so the top thread isn't pulling too hard lower the tension of the top thread. This should fix it.
May 08, 2015 | Janome Memory Craft 10000
Why is my bobbin thread is showing while embroidering
Your tension on top can be loosened. If this causes your stitch to be too loose then tighten your bobbin tension. Just think of the top and bottom tensions as a tug of war. They must be even to get the stitch in the middle of the material.
Jul 31, 2014 | Baby Lock Sewing Machines
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
Bobbin tension
The bobbin case has an adjustment screw for the tension at about the 6 oclock position as you look at it in the machine. Turn it clockwise to tighten.
Apr 12, 2010 | Janome Memory Craft 9000 Computerized...
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
The bobbin thread is sewing loose - after sewing you can just pull the thread out. Stitches are uneven in length some short some long.
Tighten the bobbin thread a little and loosen the top thread tension a little. A correctly tensioned embroidery machine will show a little less than 1/3 of the top thread color and 2/3 of the bobbin thread on the bottom side of the embroidered piece. You may have to play with it some so use scrap material and dark top thread until you get your adjustment made.
Oct 11, 2009 | Janome Memory Craft 9000 Computerized...
Once I set up my design card and select design, the needle moves
Hi, and welcome to FixYa. If I understand your problem, the needle goes in and out of your fabric, and the embroidery hoop moves, but the machine does not actually start embroidering your design right away....did I get it right? If have time to answer a few questions, I can give more accurate instructions.
  1. How long have you had your machine?
  2. How long have you been doing machine embroidery?
  3. Do you have a manual for your machine?
  4. Look at the back side of your design - do you see lots of bobbin thread, or hardly any?
  5. Have you taken lessons for your machine or for embroidery?
  6. When your design is finished, can you where the machine skipped stitches?
Here a couple of things you can try (if you have already):
  • Make sure you use an embroidery needle, not a universal. In most cases, you should use a size 90. Change your needle after each project. A blunt need can cause your machine to skip embroidery stitches anywhere in the design.
  • Rewind or replace your bobbin. Make sure you use bobbin thread in your bobbin when you embroider - it is thinner and gives you better tension. If pre-wound embroidery bobbins are compatible with your machine, I recommend that you try one and compare the result with designs sewn using the bobbin thread you've been using.
  • Normally, you should loosen your tension a little bit when you embroider. When you look at the back side of your embroidery, you should see more bobbin thread than embroidery thread.
I owned an embroidery business for several years, and I have six different embroidery machines of my own - so with a little more info from you, I think I can help.
Feb 03, 2009 | PfaFF Creative 7570
Janome memory craft 5700, purchased 2004
Take out your bobbin case and examine it for nicks, scratches and or rough spots.If the problem is not too bad it may be possible to buff out the bad spot with an emery stick or emery cloth. If that isn't possible or it makes too much noise after you buff it you will have to replace it. Look especially along the edges and underneath.
sewman7
May 22, 2008 | Janome Memory Craft 5700
Mc 5700 problem
Check for loose threads or fluff in upper tension unit and bobbin case tension gauged to 14g resistence. Otherwise, service time I'm afraid. Have it serviced by an authorized Husqvarna Viking Service Technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Feb 07, 2008 | Husqvarna Rose
Bobbin Thread
I have had the same problem. I always just used the same color of bobbin thread as on the top. It is a pain to change inbetween each block, but the designs usually look perfect. I will have to try playing with the tension.
Sep 24, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
146 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
