Question about Ubi Soft Catz 5 (Windows) (680901) for PC
Petz 5 not working. error message comes up
I have windows Vista. Petz 5 has worked for months since I installed it, then suddenly one day when I clicked it, it showed the loading screen/bar. The bar stops at about almost half full, then says 'Petz 5 stopped working...' and closes. I have tried EVERYTHING. Restarting, reinstalling. It always says this. There is nothing wrong with the disk.. please can someone help me? Everytime I run Petz 5, it runs nearly the full way but then stops and says it needs to close and has an error, sorry for any inconviniense. iTS REALLY ANNOYING and have tryed everything to stop it. PLEASE HELP
If you keep getting error messages its usually because you have too many petz, I used to get error messages all the time. To solve this problem create an empty folder outside of the petz program file, copy all your petz in the adopted petz folder of petz 5, mythos studios, ubisoft in program files. Once you have all your petz safe in this other file, empty the adopted petz one in the program file, you now have a petz game with no petz on it but it should work. Copy the petz you want to play with back into your adopted petz folder, its true you can't have all your petz available for selection straight away but you can swap each petz file from your safe file with all petz in back to the file that is used for game play. Note: If your petz don't appear straight away try opening and closing the program.
Posted on Jan 08, 2011
  • irina_wolf
    irina_wolf May 11, 2012
    I had 3 petz. Now way that's too many
  • pop_pie2009
    pop_pie2009 Oct 13, 2012
    THANK YOU VERY MUCH!! :)
    Problem Solver:
  • 18 Answers
When you unintall Petz 5 you need to not save the petz, which is an option just before it starts uninstalling. Unistall, Then install it again, and run the game from My Computor, Petz, then play.
hope it works for you.
Posted on Jul 21, 2009
HElp Meee!!!!!!! I Just Downloaded Petz A a few weeks ago I played Petz 5 And The second time I played it I set the settings so it would pop up on desktop
And When It loads the scene A black Screen Always Comes Up First Right? But The Game Goes Really slow and The black Screen Wont go away. I cant Even Play It! :( Please answer I miss my petz
Posted on Nov 11, 2011
Pets Don't Have Faces
Check that you are running in compatable mode. Since Windows 7 is so new not all programs run properly so you should have a link to run the program in a compatable stage. If not check and make sure your program is compatable with Windows 7. You may have to reinstall the program and you will probably get a message to install in a compatable mode. If you do make sure you install in that mode then the program should work. Windows 7 is like when they first came out with Windows Vista there are a few bugs that they are still working out and that is probably what is causing the problem.
Jan 10, 2010 | Ubi Soft Petz: Dogz 5 and Catz 5...
Tip
How To Fix A Non-Loading Problem On Petz 5
I have written this so many times, that I decided to make a tip out of it so I dont have to keep answering the same question over and over.
To fix the problem when your loading thing doesnt load fully, and it comes up with an error message, you need to follow these instructions.
a)Save your petz to a flash drive, or CD or floppy disk. NOT to the computor as they will get deleted. (this step is only if you want to keep your petz)
b) Uninstall and click "No" to "Do you want to save your petz?"
c) Install again.
d)Put your petz back on your game, by putting the Flash Drive/floppy/CD into the computor and copying the petz files into the petz folder. (if you kept your petz)
e) Play the game from My Computor, Petz 5, Play.
You will need to have the disk in whenever you want to play for e) to work.
If this doesnt work, ith saving your petz, skip steps a), and d).
Hope this tip helps. :D
on Jul 22, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
Error Message For Petz 5
When you reinstall the game do you click 'yes' to 'do you want to save your petz'?
You need to click 'no for it for work. You will lose all your petz.. but its the only way (that i know of) to get ur game working again.
Also, when you go to play the game, go to My Computor and click on Petz5 to play, instead of playing it from the shortcut or whatever. That means you need to have the disk permentently in.
And, when you fastforward (time glitch) only forward one day at a time (opening up petz after you forward, closing, and going forward another day).
Hope it works :)
Jul 20, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
I'm using windows vista. petz 5 worked well at first but then suddenly i keep getting resource id = 1020 errors from the program, and it closes itself. what is this and what do i do?
Updates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NUpdates to the IIS metabase were aborted because IIS is either not installed or is disabled on this machine. To configure ASP.NET to run in IIS please install or enable IIS and re-register ASP.NET using aspnet_regiis.exe /i. OR user@domain.com failed an operation on
Jul 08, 2009 | Ubi Soft Petz: Dogz 5 and Catz 5...
Petz 5 not working.
Right-click on the Icon > Go-to Properties > Click the "Compatibility" tab > Click the check box next to "Run this program in compatibility mode for:" and select Windows 98 or Windows XP if available.
You may need to disable visual themes or other options.
Hit apply once you are finished configuring.
May 07, 2009 | Ubi Soft Catz 5 (Windows) (680901) for PC
My catz5 game won't lauch!
Try to reinstall the game and get windows vista....although mine says the same thing XD
Nov 05, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
Dogz/Catz 5 compilation Vista Help
Firstly, open a folder. You need to click on 'Organize' >> 'Folder and Search Options'. On here click on the 'view' tab, then check the box for 'Show hidden files and folders'. Click OK on this.
Next go onto C: and click on your user name, then click on AppData.
In here, click on 'Local' >> 'VirtualStore' >> 'Program Files' >> 'Ubi Soft' >> 'Studio Mythos' >> 'Petz 5' >> 'Adopted Petz'.
Here is the file path if you need it:
C:\Users\Your User Name\AppData\Local\VirtualStore\Program Files\Ubi Soft\Studio Mythos\Petz 5\Adopted Petz
Hope this helps!
Jenn xo
Sep 15, 2008 | Ubi Soft Petz: Dogz 5 and Catz 5...
Petz5 installed giving me error report
I had this same problem. So what I did was I went to the Petz 5 folder and clicked on Adopted Petz. I moved all my pets into another folder. Then I uninstalled and reinstalled the game, moved all my pets back into the Adopted Petz folder, started up the game it it was all good! Hope it works for you!
May 27, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
HELP!
what actually happeneds when you try to start Petz up?
i dont really undertstand ur problem.. and Petz A shouldnt make ur game die.. or whatever that happened to it. you can try uninstalling and installing.. and then playing from My Computor..
if that doesnt work, please post again w/ more details.
and please, please dont talk in caps.
May 05, 2008 | Ubi Soft Catz 5 (Windows) (680901) for PC
Dogz 5 Won't Work!
This happened to mine 2. I uninstalled it, but the folder was still there, so I went on search, local disk, and searched ubi soft then deleted it. After that it worked, except I've noticed if you press save pets when uninstalling, it doesn't work.
If I want to keep my pets, I go into the ubi soft folder, adopted petz, then I drag my pets to a new folder I make on the desktop. When the game is reinstalled, I put the pets in the folder back into the adopted petz folder.
This has been the solution for me, but I don't know if it will work for others. Good luck!
Nov 25, 2007 | Ubi Soft Catz 5 (Windows) (680901) for PC
Open Questions:
See all Ubi Soft Catz 5 (Windows) (680901) for PC Questions
Ubi Soft Catz 5 (Windows) (680901) for PC Logo
936 people viewed this question
Top Ubi Soft Computers & Internet Experts
Piyal Perera
Piyal Perera
Pavel Pranovich
Pavel Pranovich
k24674
Are you an Ubi Soft Computer and Internet Expert? Answer questions, earn points and help others
